Question about Brother XL2600 Mechanical Sewing Machine
On my girlfriends Brother XL 2620 the needle has hit the bottom plate and snapped the needle It looks like it's come out of line ???? Is there any way of adjusting this ? Or should I take it to a specialist shop to have it fixed ? Thanks for any help Edd
  • Brother Master
  • 7,365 Answers
Breaking a needle a can make the machine go out of time.
and timing a machine can only be done by a sewing repair tech.
Posted on Aug 06, 2011
SOURCE:
Needles hitting inner mechanism
it sounds like the machine could be out of time, I would suggest taking the machine back & getting another one.
Apr 01, 2012 | Brother 1034D Mechanical Sewing Machine
My Brother XL-5021 sewing machine has stopped working and won't pick up the thread from the bobbin.
it's called being out of time,,and the machine can only be timed by a sewing machine repair technican,, because they have the tools for job
Feb 01, 2012 | Sewing Machines
The needle hits the metal plate
it sounds like it's out of time & needs to be serviced by a techican that has the tool to time it
Aug 11, 2011 | Brother XL-2600I
Using a universal pleating foot, starts out fine then I break a needle, 5 so far. It hist the pressure plate. Using a straight stitch, needle is centered. Bobbin is treaded correctly. Needle is straight at...
Sounds like the needle is hitting the moving part of the pleater once you get going, getting bent then striking the needle plate too.
Its not going to do the machine any good if you keep striking it with the needle as you'll end up putting the timing out.
As the pleater is a generic type it is probably best to stop trying to use it on your machine.
Jun 26, 2011 | Brother XL-2600I
I keep breaking the needle because when the presser foot is down it hits the plate on the bottom of the machine
Refer to your manual, it gives all sorts of reasons for the needle to break, wrong bobbin size, scratched plate, needle being inserted wrong. If, you do not have your manual go online to
brother-usa.com and download one for free.
Sep 11, 2010 | Brother XL-3500
Free motion quilting
Refer to the accessories and you will find one is a darning plate. If you check the section for darning, there will be more information.
Look on the throat plate and there should be a tiny hole on each side of the feed dogs, this is where the plate snaps into place.
If you do not have the plate, set the stitch length to zero, and then tape an index card over the feed dogs with a hole punched out for the needle.
You may use this method forever, or check with your local Brother dealer for the accessory.
May 01, 2010 | Brother XL-5340 Mechanical Sewing Machine
HI, my brother xl-2600i is hitting the metal on the bottom not going through to the bobbin. don't know what to adjust. help! thanks in advance.
First, check to ensure your needle is not bent. If its not bent then just adjust your metal plate at the bottom. Loosen the screws and shift the plate back, tighten the back screw first and see if the needle now passes the plate. If not make some more adjustments. Once the needle passes the plate properly, tighten the front screw. Hope that helps.
Apr 13, 2010 | Brother XL-2600I
Needle getes broken
Check to see if your needle plate is gouged or signs that the needle is hitting the plate. If so, you may be pulling a little too hard when the fabric is feeding. Sometimes when you pull too hard, it pulls the needle back and it will hit the plate instead of going into the needle hole and you will break needles. Try just letting the fabric feed itself and you simply guide it to make sure it stays in a straight line.
Feb 07, 2009 | Brother LS-2125 Mechanical Sewing Machine
Brother XL2600 Mechanical Sewing Machine Logo
110 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
