SOURCE: Epson stylus CX3600 E light flashing, all green lights flashing
Restart your computer and power-cycle your printer off and back on.
Make sure the paper tray is not overloaded.
Make sure the paper in the tray firmly pushed into the paper tray towards the printer.
SOURCE: Epson Stylus CX3600 error
remove the cartridges then, the press and hold all the available buttons on your printer where it could cause a machine resetting...
you could also remove the cartridges then wipe the circuitry of the cartridge... (the gold-like connector)
then turn off your printer without putting back the cartridges... (leave it turned off for 5 minuets)
turn your printer on then it should be ok
(post back if it doesn't work)
SOURCE: epson stylus CX3600 E light flashing, all green lights flashing
CX3600- 8 FLASHING LED`s and Error code
SOURCE: i need reset software for epson cx3600 as i have
The SSC utility will allow you to reset the waste counter on this printer... You may find that this is a general error though in which case resetting won't make any difference.
Link for SSC:
http://www.ssclg.com/epsone.shtml
