Hi
You have to check for a faulty speaker inside. make sure that it is OK, and then follow the audio output section circuit, to locate the fault.
It sounds that there may be some loose soldering point at somewhere on circuit board.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name of your device at its search box to get gathered the related posts. View it on desktop. Mobile view has no search box.
If you view it 'on web view' at mobile, there is search box.
T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Yes it can be fixed . it is possible that you might have your TV's Y-sus malfunctioned so it needs to be changed If you tell me the model of you 60" tv i might be able to supply you with more informations
I have the same problem. Good picture with no sound at all. I have a LG DVX583KH and LG TV LM7200. I connected the DVD player to TV via HDMI cable, I have a clear picture but no sound. I try to hook up the DVD to other TV and it works both sound and picture. Please help
