HP Laserjet P3015X Printer Logo
Posted on Aug 06, 2011
I want to reset my printer, HP Laserjet P3015 to default, like as if it were a new printer with default settings.
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Aug 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
Helped
14311
Points
36
Press the Menu button I want to reset my - c01779038.gif , select the CONFIGURE DEVICE menu, and then select the RESETS menu. RESTORE FACTORY SETTINGS. Clear the page buffer, remove all perishable personality data, reset the printing environment, and return all default settings to factory defaults. Hope this helps.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 11, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
12727
Points
The above is incorrect. You need to scroll to Service and Restore Defaults.
How do I reset hp laserjet p3015 to factory settings
  1. Press the Menu button .
  2. Open each of the following menus. Press the down arrow to highlight it and then press the OK button to select it. CONFIGURE DEVICE. RESETS. RESTORE FACTORY SETTINGS.
How to reset hp 3015 reset
P3015 printer to factory defaults you need to follow the steps listed below.
First make sure the printer is turned on.
Next push the button labeled menu.
Push the down arrow until you reach the Configure device option. Select this option.
Push the down arrow until you reach the Resets menu. Select this option.
Push the down arrow until you reach the Restore Factory Settings option.
Select this option and the printer will restore to factory defaults.
Hello! I have a HP P3015 LaserJet Printer show
you need to go to the printer on computer, then to the port settings and use the usb dot 4 port - will be that
There is an error code on my HP LaserJet P3015 which reads 49.4C02 ERROR
HP LJ P3015 with 49.4c02 error - tried lots of things in the end went into printer driver right clicked and then clicked troubleshoot - windows came up with a fix dont know if it is permanent - troubleshooter said a print job was deleted from the print queue. Presume the printer tries to print the problem job in the queue each time it is switched on.
1helpful
2answers
HP P3015 reset maintenance kit count
  1. Power off the printer.
  2. Power on the printer while depressing both the Go and Cancelbuttons. Keep the buttons depressed. The lights will begin to flash in sequence.
  3. Release the buttons when all three lights begin to flash in unison
16helpful
3answers
Configure ip adress to hp laserjet p3015
This model does actually have embedded network functionallity.
To configure the IP Address, follow the menu map as below:
1) - (4) I/O
2) - (4-2) Embedded JetDirect Menu
3) - (4-2-2) TCP/IP
4) - (4-2-2-1) Enable (Make sure this is 'On')
5) - (4-2-2-3) IPV4 Settings
6) - (4-2-2-3-1) Config Method (Auto = DHCP, Set to Manual in order to specify an IP address.)
7) - (4-2-2-3-2) Manual Settings (This is where you can set the IP Address, Subnet Mask, and Default Gateway.)
17helpful
2answers
51.10 ERROR
i cant print my document my hp laserjet p3015 print display error message 51.10. please slove this imdy.
k24674
Grand Canyon Tech
Grand Canyon Tech
