If the electronics haven't crapped out, it's likely dirty. It takes considerably more signal to have color than B&W. Cleaning the heads should help. If you don't know how, let me know and I'll walk you through it.
Alternately, a few of the VHS and 8mm units had a black and white mode setting in the menus. Recording B&W movies in color mode caused some oddball effects, from time to time, so they offered a B&W mode. It was a short lived option because people didn't want to bother with it, and it occasionally got enabled accidentally, leading to complaints and visits to service centers.
Sounds like a case of dirty heads on the VCR. You can try using a head cleaning cassette (Radio Shack has one on their website, so it might also be available in stores, or you can search for other vendors online). Or you can see if there might still be a service shop or video rental place in your area that offers cleaning. It's getting tough to find service on VCRs as they give way to DVDs. All it takes is a little oxide from a worn tape to cause the symptom you're seeing.
Though Connection details are available in DVD recorder User Manual, yet here is procedure. Find Video Audio Out terminal on Cassette Recorder SLV-SE610G and hook Yellow-Red-White cable in matching color pins and other end of cable will hook in Video Audio Input terminals at DVD Recorder RDR-GX3 and please note, same color pins will be hooked. Insert desired VHS cassette in VCR and push Playback. select input source at DVD Recorder and confirm playback picture and sound of vcr at TV. Now system is ready to record VHS movie on DVD.
If you need further info, please post back here.
I was having the exact same problems, and I read a post on this website somewhere recommending that I just record a few seconds of video on a blank portion of tape and then the camera should start playing video normally again.
already tried and did not
