It sounds like it could be a faulty bearing in one of your wheels, a worn ramp or a combination of the two. The following link will take you to our Precor page. Please reference your model and serial number. This will allow you access to the correct parts and manuals for your machine.
Precor Elliptical EFX Repair Parts Belts Wheels Pedals SPORTSMITH net
SOURCE: The ramp will not go up or down. It's states low
The ramp system has a battery monitoring system. If the battery voltage falls below 11 Vdc when the ramp movement is initiated or the battery voltage falls below 10 Vdc after ramp movement has been initiated, ramp movement will be stopped and gives that error message. The ramp will not be enabled until such time as the battery voltage exceeds the above limits. The battery voltage must be raised to be to correct this problem either by charging or replacing the battery.
SOURCE: where do you find the
you must have an incompetent boyfriend ... chuck him out then throw the machine out on top of him ..
