SOURCE: HDTV
I don't think the DCT2244 has an RF bypass output and it is not HD enabled. Hence, you will need a cable splitter so that the unscrambled splitter outputs can go to the TV and the CABLE BOX independently. This will enable you to pick up any available unscrambled HDTV signals your provider offers as well as the channels you are subscribed to that require the box for decoding.
SOURCE: Can't connect the Zebra 105SL printer through RS232 port.
And, once you have the null modem adapter or cable, you need to make sure the serial settings on the printer match your port settings on the PC.
SOURCE: Are there any special requirements for replacing
make suse you replace upper strut mounts as well. before you remove strut secure rubber block with supplied bolt.
SOURCE: Jack requirements
You can use a standard RJ-14 two line jack. This type of has a minimum of 4 wires inside the jack. You can also use a 6 wire jack, but not a 8 wire jack.
SOURCE: TELEPHONE HOOK-UP REQUIREMENTS
Just a plain telephone cord, plug it in. Go into setup and setup your fax name and number that will appear on the fax your sending. Set the number of rings before answering. Place a test fax call to some fax machine.
If you do not receive a return fax within 5-7 minutes, there may be a problem with the setup of your fax machine. Consult the user manual that came with the product for proper setup and configuration.
