SOURCE: Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
SOURCE: washer's warm setting alternately fills hot and cold
Call for wty svc- the temp switch is bad; they had many of these built like that Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
SOURCE: Washer won't agitate, drain or spin
Hi Xinia_s
The lid switch needs to be replaced. although it seems to be working for the water intake valves it will not work for the motor. it is not the fuse. the main fuse sits right above the motor's start capacitor in the lower left side of the lower cabinet; had it been the fuse it would'nt even fill w/ water. have the lid switch replaced and it should do the trick.
SOURCE: Maytag Washer MAV7000AWW Washer fills as it
Sounds like a bad timer motor.
Try watching the timer motor and see if you can see it moving .
SOURCE: My washer fills with water and keeps filling
The problem is simple and easy to fix. Your washer has a tubing which runs from the base of the tub to the water pressure switch. It might have vibrated loose from the switch, or their can be some sediment in the tub. Blow out the tubing and reattach it securely to the switch and pump out the water in the tub. Then try it again. I wrote an article about this:
Help my washer is overflowing !!!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
