Question about LeapFrog My Pal Violet
I installed the software and connected the toy, was able to select all my daughter's info and favorites, music etc, and at each step it said successful, when I disconnect the toy from the computer all that happens is th collar light flashes, there's no audio! Brand new from the store, so I changed the batteries and reinstalled, still no sound! Any suggestions before I take it back?
4 Suggested Answers
SOURCE:
  • 8 Answers
SOURCE: my dauhter got the leapfrog
You have to download the software for your computer that allows you to connect Violet in order to change the name, etc. Once you do that, connect Violet with the cable included and follow the steps. If you need more help let me know. It's a little tricky sometimes if you don't do things in the precise order.
Posted on Mar 30, 2011
damneddle
  • 1607 Answers
SOURCE: Hello. My daughter's Leapster
Have you tried putting new batteries? If yes and still has no sound then look for the warranty and bring it back to the store where you bought it so they can repair it for free.
Posted on May 15, 2011
  • 794 Answers
SOURCE: My new leapfrog fridge words
Hi louconn,
Changing the battery will not really resolve the issue. It has something to do with the inside part of the toy. The most likely cause o f this are tabs that are pressed down or half pressed down. There are six per spot, which is how the system recognizes each letter. But since this is new. I would highly recommend that you send it back so you can a replacement.
Hope this helps.
Thank you for using FixYa.
Posted on Jun 14, 2011
I purchased some software to monitor calls on my daughters cellphone. the software was sent to me and i need to save it to my computer and then download it to my HTC thunderbolt phone. how do i do this?
The software installation file you have purchased is in "APK" format which is what Android will recognize as an application installer.
To install applications outside of the Market you must select/check "Unknown sources" which is located under "Applications" which is located under "Settings."
1. Connect the HTC Evo to your computer via it's USB cable.
2. Select mode of connection as "Disk Drive" (a menu with these options will pop up after connecting through USB).
After that is done, your computer will now recognize your HTC Evo as a Disk Drive.
3. Go to the location of the file you've download and want to transfer to you daughter's Evo- Select it, hold down "Ctrl" key while pressing the letter "c" (to copy the file).
4. Go to the location of the HTC Evo now known to your computer as a "Disk Drive" then hold down "Ctrl" key while pressing the letter "v" (to paste what you've copied).
Now that the file is on your daughter's Evo you simply need to:
1. Change the Evo's mode of connection from "Disk Drive" to "Charge Only" or just disconnect the USB cable.
2. Browse to the phone's app directory to start a file manager application (download one from the Market if you don't already have one- I recommend "ASTRO File Manager").
3. Navigate (using the file manager) to the file you've transferred to the phone and just launch it. The next prompt will ask if you want to install the application- select "Install."
Done.
Aug 13, 2011 | HTC EVO 4G Smartphone
Tip
Enjoy Video and Music on Sansa View, Sansa Fuze, MP3 Media player
Questions: You are so excited to the large capacity and nice sound quality of Sansa player, yet you are confused to put your favorite videos to your Sansa Fuze, Sansa View, Sansa MP4 Movie and other Sansa players. How to convert MP4, MOV, M4V, AVI, FLV, SWF, MPG, ASF, WMV, MP3, AAC, M4A etc. to Sansa media player? This guide enables you to full enjoy on your Sansa MP3 and Video player by Sansa Video Converter for Mac. Solution: step by step guide to enjoy music and video on Sansa media player.
Preparation:
Software: Doremisoft Sansa Video Converter
System Requirements: OS Supported: Mac OS X v10.5
Hardware Requirements: 512MB RAM, Super VGA (800×600) resolution, 16-bit graphics card or higher
Download Now
Step1: Connect your Sansa video or MP3 Player to your computer through the USB connection.
Step2: Download Sansa Video Converter for Mac and run it.When you have installed this Sansa Video Converter, it will pop up the screen like below.
Step3: Add Video or audio files to Convert.Click "Add File" button to load your videos from your computer. Select the video files you want to convert. Also you may preview your video by clicking the left play button.
Step4: Preview and Select Click a file in the List or select several files. You could preview videos to play the file.
Step5: Edit the video with the function button:Clip(Merge, +/-), Edit(Crop, Effect, Rotate), Settings
(1)Clip:
You can cut your long videos into small clips or get more than one segaments just clicking "+/-". Besides, merge two or more video files into the whole successive one.
(2)Crop:
This function helps you cut off the undesired area from your movie video and choose your favorite clips to convert.
(3)Effect:
In the "Effect" selection, You could tune the Brightness, Contrast, Saturation and Volume to get special effect movie, in addition, you can Select Emboss, Gray, Old Film effect from Special Effect.
(4)Rotate:
Change video play direction in180, horizontal or vertical way to watch videos.
(5)Settings:
If you want to customize the output video’s quality, you can click the "Settings" button to open the settings window and set video Resolution, video Bitrate, Audio Channels, Audio Bitrate. Also, if you do not set them, the software will use the default setting to convert.
Step6: Select the format for your Sansa files. You may select "Sansa Video MPEG-4 (*.MP4)".
Tips: This format is to generally use. If you want to convert your videos into portable players you'd better select format according to your player. Then the output videos would be much more compatible with your player.
Step7: Start to convert the files.Check: Click the right convert button. The converting process will begin. Please wait before the converting successful in a few seconds.
Well done. Now you can enjoy your favorite music and videos on Sansa player everywhere.
on Feb 25, 2010 | Computers & Internet
Cant seem to be able to download music onto it off computer didnt get any instructions with it
Hi Oligan10,
Attached below are 10 easy steps to get you started in playing your favorite music using your PSP.
step 1 Take a USB 2.0 cable and connect the PSP to your computer step 2 Press the home button on the PSP step 3 Use the left and right buttons to find Settings ( select by pressing the X button ) step 4 Select USB Connection -Your computer will notify you that a new USB device has been connected This should show up as a new hard drive with a corresponding letter identifier step 5 On your computer, select the correct drive letter and open PSP file system step 6 Create a new folder and call it PSP step 7 Go inside this new PSP folder and create another folder. Name it MUSIC step 8 On your computer hard drive, Select the MP3 music files that you want to transfer and save it into the MUSIC folder that you have just created step 9 Disconnect the PSP from your computer by pressing the O button step 10 Unplug the USB cable.
To View and Play the downloaded music on your PSP :
- Use the left and right buttons and select MUSIC - Select Memory Stick by pressing the X button You should see all the music files you have just transfered to the PSP.
I have attached a link to the PSP Manual, should you need more information about your PSP. http://www.fixya.com/support/p201358-sony_playstation_portable_psp_console/manual-16250
All the best to you my fellow PSP enthusiast.
Jan 26, 2011 | Sony PlayStation Portable (PSP) Slim...
My dauhter got the leapfrog my pal violet dog for christmas before receiving this my brother programmed in my daughters name and colour ect i want to change and add info myself but when connect the toy...
Dec 29, 2010 | LeapFrog My Pal Violet
How do i put music no my mp3
follow the steps below:
  1. Put a CD of your favorite music into your computer, and then open your mp3 player. Click on the music that you want to copy.
  2. Click on the "Rip" button, and then save your music with any of the following file extensions: .wma, .wmv, .mp3, .jpg, .mp4, .m4v, .m4a, .m4b or .mov.
  3. Plug your mp3 player into your computer using a USB cable, and then the mp3 software will automatically import all of your selected music into the player. Set the "Sync" option to "Default" so that all the music in your directory will install in your mp3 player whenever you plug it into your computer.
I hope the above steps will help to solve your problem.
Take care.
Jun 10, 2010 | Audio Players & Recorders
What are the steps to update my iphone
Here is simple guide for those Users who will be first time upgrading their iPhone 2.2 or 2.2.1 to firmware 3.0. The guide is applicable for Upgrading iPhone 2G/3G 2.2 or 2.2.1 to OS 3.0 and also for iPod Touch. Please note in order to upgrade iPhone to firmware 3.0 you must have installed iTunes 8.2.
How to Upgrade iPhone 3G 2.2/2.1 to 3.0 firmware 1. Connect your iPhone 3G to computer
2. Open iTunes 8.2
3. Select your iPhone under Devices in the Source List on the left.
4. In the iPhone Summary pane, click Check for Update.
5. Click Download and Install. Do not disconnect your iPhone until the update has finished
That’s it, Once update is finished your will have iPhone 3G running latest firmware 3.0.
Please rate this solution
RNJ VINODKUMAR
Oct 02, 2009 | Apple iPhone Smartphone
Playing music on htc hero from itunes library of macbook
One issue should go first ahead of your question --- is the music you want to transfer from iTunes DRM-protected?
1. If they are non-DRM .mp3 or .m4a, you can either use one-stand free iTunes transfer like DoubleTwist or iTunes Agent which dose good job of transferring iTunes music to HTC Hero; or you can manually frag and drop by following those steps:
Step 1. Plug in your phone via-usb to Windows Computer
Step 2. From the "HTC HERO Phone" pull down drop-menu from the top and select with your finger the menu that says "USB Connected Select to copy files to/from your computer.
Step 3. Select Mount ("on the phone")
Step 4. The Default Windows Removable Disk shows up (on the computer), select open folder to view files. Here you will see the phones & applications file structure.
Step 5. Select the file that says DCIM then 100MEDIA this is location for your music, pictures, and videos.
Step 6. Open up My Computer or Windows Explorer in a seprate window on the computer and copy and paste your files into the 100MEDIA location.
Step 7. Final step, from the phone pull down the drop down menu from the top and select Turn off USB Storage - Turn off - you will see SD Sync.
2. If they are DRM-protectd .m4p music .m4v video files or other protected .wma wmv files, a 3rd party DRM Removal Software is a must-have tool to strip DRM license and convert format to HTC supported .mp3 audio and .3gp video.
Transferring is as easy as what was stated above.
For detailed info, you can check the following tutorial:
How to sync iTunes Amazon music video DVD movie on HTC Hero Touch HD, Pro, Diamod etc
Sep 21, 2009 | HTC Hero Smartphone
Loss of music library
Uninstall everything from your PC, reboot, reinstall driver and the Explorer (I do not use MediaSource, only the Explorer).
If it didn't work out follow these steps:
1. Uninstall Creative Media Source and all related software.
2. Install the driver. In the installation CD the driver is usually in \Drivers\English
3. Turn on the Nomad an connect it to the PC.
4. Install MediaSource(the program requires that you have the nomad connected while installing)
5. Install MediaSource plugin
6. Try transferring files.
If you?re still running into problem know that there are other programs capable of handling MediaSource?s functions, such as - Portable Audio Devices Power Toy , NomadSync, Real player, and there?s also a Zen plugin for the Winamp.
Jun 23, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Get pictures and video off phone to the computer
Preparation ? if an external Micro SD external memory card is to be used as the desired music/video/picture repository on the W755, install the card in the W755 behind the battery. Then go to SETTINGS & TOOLS ? MEMORY ? CARD MEMORY ? FORMAT and format the new card. Caution: reformatting the card will wipe out all contents on the SD card. Download/install free Motorolla Handset USB Driver Installer onto the PC (execute ?.msi? file). Download/install free VCast/Rhapsody software (no need to actually sign in or use the proprietary Rhapsody service). Start the VCast/Rhapsody software. Turn on cell phone (works with W755 and may work with other Verizon ?music phones? such as LG Chocolate, but the latter was not tested). Connect phone to PC ? connect USB cable to PC?s USB port first, then connect USB cable to phone . Be patient, it may take a minute to fully ?connect? in the phone?s display. Go to ?Sources? section of VCast/Rhapsody GUI screen ? the phone will register as a directory title using a name roughly like ?VCast xxx.? Windows Explorer will also show a ?VCast? drive/directory device. Files can be selected and dragged to and from source and target directories. At this point various options exist regarding music, picture, video management: 1.) The VCast/Rhapody software can be used to manage music, picture, and videos between the PC and phone. Again, no need to use the VCast service, just the software offline. 2.) Alternatively, other music management software such as Media Monkey (a personal favorite) can be used to move music, create playlists, etc. ? NOTE: Leave VCast/Rhapsody software running in the background as a means to ?connect.? It is best to start VCast, then plug in phone, then start other media management software so that the media management software will benefit from the connection (usually with a directory name using some variation of ?VCast.? Then use the alternative media management software as usual. Please note, this is a generalization based on success using basic software like Media Monkey, for example.
Apr 26, 2008 | Motorola Cell Phones
LeapFrog My Pal Violet Logo
81 people viewed this question
Top LeapFrog Toys Experts
Nikki  Mclean
Nikki Mclean
pramey3
Level 1 Expert
Keith Koene
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
