HP DeskJet F380 All-In-One Printer Logo
Posted on Sep 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nothing happens when i tried to print from my computer the status is offline what is wrong
  • the status is offline and its not printing what is the problem and how can i fix it
  • rdsls2 Sep 04, 2008
    same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
  • amaranu Sep 07, 2008
        a red light is glowing below the power on light.
        the E letter is glowing below it.
        neither copy nor printing is getting done.
        scanning is ok.
        status is showing offline.
    i have reset the device. detached the cartridges and re-attached. opened the back door and checked for paper jam.
brian williams
Level 3:
Genius:
  • Master 1,980 Answers
  • Posted on Sep 12, 2018
brian williams
Master
Level 3:
Genius:
Answers
1980
Questions
9
Helped
741574
Points
5402
Power cycle printer and router.
A
Anonymous
Same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
POwer botton flashing light.. cant print and the status is offline.. how can i fix this problem pls help
The flashing light is because the printer will not print if it's offline. Be sure the printer is connected to the Internet. It may be offline because you have tried to print too many documents. If that's the case, you will need to delete all the documents that have been sent to the printer and haven't printed. Don't delete the actual document from your computer, but from the print queue. Hope this helps.
11helpful
6answers
Epson printer offline
In this section, we provide some practical ways to resolve the Epson Printer Offline Issue. Simply follow the mentioned teachings carefully and fix this error on your own.
If your Epson printer is displaying an offline message, it means that there is some connectivity problem between the Epson printer and PC. ... Incorrect printer settings where your printer is not set as "Default Printer" may make your printer go offline. An outdated printer driver may stop your printer from functioning.
In the same way, How do I put my Epson printer back online?
Verify The Printer Connection
Update Epson Printer Driver
Check Printing Status
Restart The Print Spooler Service
Add A Second Printer
Hopefully, now you can surely Resolve this issue. I Hope, this content is valuable for you to solve the Epson printer says offline windows 10.
Epson Printer Not Connecting to WiFi
Epson Printer is Not Responding
When trying to print nothing happens just a green
please check ur printer connections
check the printer statuse offline or online keep it online
if its not working please install printer driver
1helpful
My printer wont print from the computer.
hi friend
this is very common problem for f300 series PSC
just delete the printer from printers and faxes and reboot the machine it will install printer again
there is funny thing abt this series it is saying offline when powered on and connected but when you disconnect iit will say "offline-use printer offline"
please try my solution and rate it
thanks
LaserJet 1600 offline status
Is the print server being assigned a IP address in your network?
Error light and no printing
What does the status monitor message say? The red light is the most general error. It's bit like taking a 747 back to Boeing and saying there is something wrong with it.
If you do not have the status monitor installed, download it from Konica Minolta and run it. Once the status monitor is running it will read the error from the printer.
k24674
Grand Canyon Tech
Grand Canyon Tech
