Whirlpool AWG329 Front Load Washer/Dryer Logo
Posted on Aug 05, 2011
I cannot get the washer dryer to start, i just completed a load of laundry came home to put anothe rone in and the red light will not turn on and the cycles will not start. Please help WHIRPOOL AWG 329
3 Related Answers
Anonymous
  • 98 Answers
  • Posted on Oct 12, 2008
SOURCE: Whirlpool Duet HT Front Load Washer- won't start
remove the plug of the machine from the power outlet and plug it after 10minutes and then check .
if the frontpannel screen shows any error codes or any lights flashing check out this link
http://www.applianceaid.com/frigidaire_frontload_washer5.html
also check out this link for more help
http://www.applianceaid.com/frigidaire_frontload_washer.html
thanks.
Anonymous
  • 121 Answers
  • Posted on Nov 29, 2008
SOURCE: No power to Whirlpool duet front loading washer
sorry no reset on that model but check the outlet
sonicboomele
sonic boom electronics
  • 1557 Answers
  • Posted on Apr 21, 2010
SOURCE: Hi I have an AWG 329 washer drier. The water won't
the pump is either broken or there is a block in the drain line sadly with these ne high tech units they can break down within weeks ive seen 3000 dollar washers and fridges writen off as quality test are very weak
I have a Kenmore Laundry Center.I washed 1 load then started another wash load. The washer filled with water completed the wash cycle and did not spin. I cannot get the washer to start again by...
Be sure there is power is coming from wall outlet and be sure breaker hasn't tripped. Also if there is a loose connection where cord was installed to unit, there may be a burnt wire.
Completely dead and lid is locked
Try an extension cord to another powerpoint. Place the drain hose in a bucket and slowly lower it to the floor, lift it up when the bucket is full, continue till the washer is empty or no more water will come out. Turn the washer off at thew wall and unplug it, wait a few minutes and plug it back in, this may reset the machine so it starts working again.
Hope this helps
Terry
3helpful
I have an lg dryer model DLG5966W and the check filter light is on. It takes two cycles to completly dry my clothes. I cleaned the lint filter and still doesnt dry on one cycle. I then removed the filter...
Check your vent. Inspect the dryer venting from the rear of the dryer to the outside vent hood of the home.
If there's a restriction in the vent--the clothing in the dryer takes longer to dry.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry. Bonus:
LG DRYER
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour.
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
2answers
Maytag 3000 Series front load gas dryer (Whirlpool) - No lights, no digital display, not able to turn on or start. Yes, unit is plugged in to AC outlet. Yes, AC voltage is good at 120V. Yes, circuit...
OK everyone, my ears are red. Over the weekend, I gave this another shot, since my warranty repair appointment isn't until next week.
I opened the dryer door (the drum light is off, indicating no power at all) and went to the circuit breaker box, and flipped the washer/dryer breaker back to off and then re-set the breaker again.
When I got to the laundry room - the drum light was on!
So I powered up the unit, and ran the machine. It ran for about one minute, and then went off. So I went back and re-set the breaker again.
Visually, the breakers did NOT LOOK tripped - but flipping the thing off and then on to re-set the breaker worked.
This time, the dryer is working fine. The bad part is: I need to replace the breaker for the second time. So this is NOT a defective dryer, it is a bad electrical supply. I will call the electrician back to make him fix this right. . . . .
Thanks again for all who responded. This is a new unit, purchased on 7/7/2009.
1helpful
GE Front Load Washer Model WBVH5100HWW - door lock light is on
I queryed another site; justanswer.com with technician Larry, who provided the solution. Replace the door latch assenbly part # WH10X1006 $146.99 from GE. A local parts house had the identical under a Whirlpool # WP8182634 for 59.46. Install the new assemble and all is well.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
