Lexicon MX200 Multi-Effects Processor Logo
Posted on Aug 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bought from usa to australia changed to recomended fuse, fuse blows as soon as turned on the unit was brand new any ideas ?
Electro Med Services
Level 3:
  • Master 6,694 Answers
  • Posted on Aug 05, 2011
Master
Level 3:
Answers
6694
Questions
Helped
1871072
Points
21433
You have to check the working voltage of the adapter of you device. If it purchased from US then it will be 110V. I think the Line voltage in Australia is 220V.Also You have to check is there is any input voltage selector in the in its adaptor . If it there you have to change it to 220V. If there is no such selector then you have to buy a 220v to 110v converter .Then connect the out put of that converter to to your device. You can by this converter at any electronic spare part shope near to you. Or you have to by a new 9V 1.3Amps AC adaptor. When you going to by the converter or a new adaptor take the device. If so they will explain you how to connect the converter or adaptor . By changing a fuse you can't change the operating voltage. If The adapter is designed to use in 110V then the fuse will blow. If you change the fuse and make more experiment with it it will make the full system useless.
ok
Testimonial: "thanks mate makes sense, cheers. "
What is the problem in a sound mixer that makes its fuse to blow
does it blow as soon as it's plugged in and turned on?
Is it a powered mixer?
If so, have you tried without speakers hooked up?
Need more info.
Oct 20, 2023 • The Music
2answers
Peavey XR8600 can't get it to come apart
And why would equipment blow a fuse the minute you turn it on? Well, I would say because it's defective. Bad power supplies, burnt components, shorted diodes and/or transistors or dead IC's. It's repair shop time bud and make sure that shorted speaker wires or defective speakers didn't damage it, as reconnecting a freshly repaired unit to the same wires/speakers could damage the unit twice.
2answers
Peavey tnt 115 blowing fuses
Very unlikely, sounds like it's faulty. Was this on plugging in or were you using the amp, and if so doing what? What is your supply oltage?
1helpful
Brand new Peavey 6505. Worked fine first day but now just blows fuse and doesn't even turn on. Will be going back but has anyone got any ideas?
Something internally has shorted...not a good indicator of this models reliability. It may pay to research another replacement brand.
Peavey Vyper Tube 120 keeps blowing fuse
You are either trying to: (A) push it too hard, (B) using the wrong type of fuse -- should be a "Slo-Blo" type, or (C) it has internal shorting or voltage modulation and requires service.
Jan 11, 2013 • Music
Still Blowing fuses
there could be something wrong with moisture. I had a drink spilled down the back of mine and I had to clean the board cause it kept blowing fuses.
Aug 18, 2017 • JBL EON 515
PMP 5000 blows fuse at start up
for a 220v 50hz 1000w the fuse is T 6 3 AH 250v
for a 100v 1000w the fuse is T10 AH 250v just make sertun thats wright or contact the manufacture address 18912 north Greek Parkway, suite 200 bothell, WA 98011 USA phone +14256720816
Top Lexicon Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Lexicon Music Expert? Answer questions, earn points and help others
