SOURCE: philips dvdr 3380/05
Go to www.p4c.philips.com
After setting you language/country options, enter the model number and search.
From the list select the model with your country code after the "/"
EG dvdr3380/05
Click on "User Manuals", then select the relevant file to download from the right hand window.
The manual can be downloded
SOURCE: philips dvdr 3320 v DVD Player Unlock region codes
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
SOURCE: Replace/Upgrade Hard Drive in Philips
email this person at [email protected] for a replacement hard drive for the philips DVDR3575H OR DVDR3575H/37
also can replace hard drive in the philips DVDR3455H OR DVDR3455H/37
SOURCE: How can I reset a Philips dvdr 3505 to it's
Press setup on your remote. Use up or down button to select( general settings ) press ok. Use the up or down buttons to ( reset all ) then press ok. Use the up or down button to ( yes ) press ok Use the up or down buttons again to select (yes) press ok. That should do it. If this works give me a vote please.Good luck.
Testimonial: "Yep that did help/work :-) thank you for such a fast response to a very frustrating problem. :-)"
To convert this player for multi-region playback
This hack should work on all Philips DVD players with any firmware version, and other similar models by manufacturers such as Grundig, Marantz and Yamaha
Please note that if you experience problems with this hack you can obtain firmware version 7.03 and later by visiting the PhilipsSyndicate to obtain files that you can burn to a CD-R and flash your unit to the new version.
1a.
The following uses the machines own remote control:
We have heard reports that hacking some players using the units own remote control incurs a 25 change limit after which it will lock the machine in the last set region
We have heard other reports that hacking some players such as the DVDR-880 using the units own remote control can result in an inoperable unit, we recommend you use the OneForAll remote only and consult our Region Hacks forum for more information
If the above does not work, you will have to send the infra-red code RC6 (aka Codeset 4, Key 235 in nerd-speak) to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital with the following instructions:
NB: Sending these codes to some players, such as the Philips DVDR-980, requires you to select a DVD player remote on the unit as the default IR device, as opposed to the DVD recorder remote it is factory set to. Please consult your player documentation to find out how to do this.
2.
The onscreen display should show 11 spaces like this: '-----------'
NB: The actual display may differ slightly depending on the model of your player, may be shown on the unit itself, or may even not be visible on some models at all.
3.
Using the number keys on your DVD player's remote control, enter the code 222 222 005 255. Note that this is 12 digits and the last digit will not show on the on-screen display.
NB: For players such as the Philips DVDR-980, DVDR-985 and DVDR-1000 units, you may need to use the code 121 212 005 255 instead. For players such as the Philips DVDR-880 you may need to use the code 121 212 005 00x instead, where x is the desired region, however this also works on other units including the DVDR-985 for setting a specific region.
4.
Press the Play button on your DVD player's remote control
5.
The onscreen display should now show the words No Disc
6.
Power off your DVD player, wait 10 seconds and then power back on
