Tip & How-To about Office Equipment & Supplies
Error 5C00 Canon ip 4600-4700
5C00 means you need to replace the purge unit,the purge unit is blocked or skipped.Try to unzip the printer and try to replace the purge unit,the purge unit is on the rigth of the printer.
canon pixma mp510-when switch on -grinding sound - then error 5C00 message - when open cover - ink assembly unit does NOT move to center - please advise
The purge unit is blocked,the purge unit is on the rigth if you open the scanner.You must unzip the printer to look at the purge unit.In the main part you need to replace the purge unit.If i have been useful please give me a vote :).Thanks
Apr 03, 2011 | Canon PIXMA MP510 All-In-One InkJet...
i am getting an error message that says 5C00
The 5C00 code is for purge cam sensor error meaning an error occurred in the purge unit. You can remove the purge assembly and clean out all the ink covering the moving parts. You can clean it with isopropyl alcohol or just water. If no luck, replace the purge unit, will be around $30. This is the part number, if you need to replace it: Purge unit (QM2-2925).
Jan 24, 2011 | Canon PIXMA MP530 All-In-One InkJet...
canon ix4000 error 5c00
Error code 5C00 means purge unit is broken. You need to bring the printer to the service center to get broken purge unit replace. I hope this short information help you. Thanks.
Find more printer troubleshooting only at: Printer Clinic
Jan 09, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
printer makes loud noises while powering on, and displays error code 5C00
Nov 23, 2010 | Canon PIXMA MP510 All-In-One InkJet...
error 5C00 results when trying to print
[5C00} & Light Blinking 4 times = Purge Cam Sensor Error. That's mean there is an error occurred in the purge unit. You may either need to replace PURGE UNIT or LOGIC BOARD to solve out this error. Thank you.
May 28, 2010 | Canon PIXMA MP830 All-In-One InkJet...
975 people viewed this tip
jasbo
jasbo
Ekse
Marvin
Marvin
