Time Setting for Models Without Calendar
Note: When setting the minute hand of a quartz watch, advance it a few minutes ahead of the time and then turn it back to the exact time.
- Pull out the crown all the way. Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.
- Adjust the time by turning the crown in the desired direction.
- Push the crown back in to the normal position. Note: If your watch has three hands,
push the crown back in to the normal position in accordance with a time
signal for "00" seconds.
Time/Calendar Setting for Models With CalendarNote: The date will change gradually between 9:00 PM and 4:00 AM. For some models, however, it will change instantly when the hands pass the 12 o'clock marker at midnight.
- For models with date calendar
- Pull out the crown to the first click.
- Turn the crown until the previous day's date appears in the calendar frame.
- Pull out the crown to the second click, and advance the hour and minute hands until the desired date appears. Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.
- Push the crown back in to the normal position. Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.
- For models with day and date calendar
- Turn the crown in the opposite direction until the desired language (bilingual) for the day before the desired day appears in the calendar frame. Note: For Cal. 7009 and 7019, push the crown back in to the normal position and then push it repeatedly to set the day.
- Pull out the crown to the second click, and advance the hour and minute hands until the desired date and day appears. Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.
Note: Do not change the calendar between 9:00 PM and 4:00 AM as it may not change properly. If it is necessary to set the calendar during that time period, first change the time to any time outside those hours, set the calendar and then reset the correct time. When the day shifts automatically to the next day, the other language will temporarily appear.
Note: When setting the hour hand, check that AM/PM is correctly set. The watch is designed so that the calendar changes once in 24 hours.
Turn the hands past the 12 o'clock marker to determine whether the time is set for the AM or PM period. If the calendar changes, the time is set for the AM period. If it does not change, the time is set for the PM period.
