Open your Kindle's Menu while on the Home screen. Do so by pressing the Menu button, or the onscreen Menu icon for Kindle Paperwhite owners. Select the "Settings" option.
Choose "Menu" again from within the Settings menu. This displays a different menu than before.
Choose the "Restart" option. Wait while your Kindle powers off and on again.
E-Reader Hard Reset
Charge your Kindle e-reader before performing a hard reset. Charging helps ensure your problem isn't related to the device having a low battery.
Hold down the Power button for 20 seconds. The screen will change after a few seconds, but continue holding the power button for the full 20 seconds before releasing.
Wait while your Kindle restarts.
E-Reader Factory Reset
Press your Kindle's Menu button. Select "Settings" from the menu.
Open the menu once more from within the Settings window. Select "Reset to Factory Defaults," or "Reset Device" if you're using a Paperwhite.
Select "Yes" in the confirmation window after reading the warning. Wait while your Kindle restarts and restores.
Fire Soft Reset
Hold the Power button down for three to five seconds. A Shutdown window appears.
Tap the "Power Off" button in the Shutdown window. Wait for the Fire to shut down completely.
Press the Power button to turn the device on again.
Fire Hard Reset
Plug your Kindle Fire in and give it time to charge before performing a hard reset. This helps ensure your issues aren't related to having a low battery.
Hold down the Power button for 20 seconds. The Kindle Fire will shut down.
Press the Power button to turn the Kindle Fire back on.
Fire Factory Reset
Swipe your finger down from the top of your Kindle Fire's screen, presenting the Quick Settings menu.
Tap the "Settings" option and select "Device."
Select "Reset to Factory Defaults," then tap the "Reset" button. Wait while your Kindle Fire restarts and restores.
You need to reset your device to factory installed settings, to use your cellphone, there are two type of reset you can apply,
1. Soft reset
2. Hard Reset
1. To perform a soft reset Remove the battery cover and using the stylus, press on the small button to the left of the battery. Otherwise simply remove the battery, wait a few seconds and then insert the battery again. 2. To perform a Hard Reset Hard reset by pressing device buttons:
1. Turn off your device. 2. Hold down the Send button, End button and Camera button. 3. Do not release Send, End and Camera, press the Power button. 4. After on-screen indication, release all the buttons.Caution, Hard reset will delete all your data from the Phone memory, including contacts, messages, or pictures you have in phone memory If you require more assistance, feel free to reply to this post Regards-BA
