This is an easy means of preventing your mobile phone from damage if it falls into water.
- quickly remove the battery
- get a screw driver that matches the screw, used to tighten the phone and loosen it.
- carefully open up the phone, without tearing it up.
- then expose to heat for about 2 to 3 hours.(DO NOT TROW INTO FIRE)
- when it gets dried, carefully disconnect the panel from other parts,
- get a mentholated spirit and a tooth brush .
- dip the tooth brush into the spirit and carefully scratch the surface of the panel with it
- when it gets dried, perfectly couple up the phone,
- insert your battery and continue using it.
it will give no problems at all if you ensure that all parts are arranged as it was before.
It works. try it..
