Tip & How-To about Apple iPod MP3 Player
Ipod problems? start with these 5 solutions!!!!!
First thing to try is a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
  • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
  • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If that doesn't solve the problem lets try another USB port
connect your iPod with a different USB port to your computer, not a USB port on your keyboard or hub.
If that doesn't solve the problem lets try restarting your pc and also make sure you have the latest itunes installed
you can get the newest itunes from
www.apple.com/itunes/download
If that doesn't solve the problem lets try reinstalling itunes, skip this if you just installed the newest version from the link I gave.
And the last thing to try is a restore
Restore
  • Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your itunes Library.
How to restore your iPod:
For Windows:
  • 1. Make sure you've reinstalled the latest version of itunes.
  • 2. Open itunes, and then connect your iPod to your computer.
  • 3. After a few moments, it will appear in the source list in itunes.
  • 4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main itunes windows.
  • 5. Click the Restore button. You will be prompted with one or more restore options that may prompt itunes to automatically download of the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
  • 6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, itunes will instruct you to leave iPod connected to your computer to complete restore.
  • 7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  • 8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the itunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Apple iPod MP3 Player Logo
ipod froze request me to go to www.apple.com/support/ipod
There are three reset variations for ipod's, depending on how old they are:
Or:
  2. Press and hold the Menu and Middle buttons until the Apple logo appears, about 6 to 10 seconds.
Or:
  2. Press and hold the Play/Pause and Menu buttons until the Apple/iPod logo appears, about 6 to 10 seconds.
I hope that helps.
Dec 30, 2009 | Apple Audio Players & Recorders
itouch is frozen
To reset your iPod:
Jul 23, 2008 | Audio Players & Recorders
black Ipod 30gb
To reset your iPod:
Jul 21, 2008 | Apple iPod MA446LL/A MP3 Player
ipod
To reset your iPod:
Jul 19, 2008 | Apple iPod classic MP3 Player
frozen!!!!
To reset your iPod:
May 17, 2008 | Apple iPod MA446LL/A MP3 Player
10,240 people viewed this tip
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Dapid Candra
Dapid Candra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
