Tip & How-To about Watches
SWATCH - IRONY CHRONO / DIAPHANE CHRONO settings
Follow this link and see how to set your IRONY/DIAPHANE CHRONO watch:
http://www.swatch.com/templates/zz_en/pdf/manuals/irony_diaphane_chrono.pdf
Watches Logo
swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
I have a swatch irony chrono, but when I stop the stop-watch and push the bottom button, the sweep hand ends up at the 11 o'clock and not the 12 position. My quartz Parnis does this, and its driving me nuts!!Thank you for any help.
Assuming the mechanics work ok (thay all do 360 degree turns) it's just a calibration issue: download from SWATCH support a PDf which describes how to zero the watch hands, it's simple as taking the crown out to 3rd step, the pushing the buttons repectively till they point 12 direction. Exact details in the PDF.
hye...my watch swatch stop functioning even i already changed the battery.
Could be Following Reason
1, Watch movement required overhaul
2, Circuit or coil warn out
3, Battery connection are not on right place
4, Test new battery to check its strength
If watch has only battery cover on the back and does not has backcase
like most of swatch watches are then watch can not be overhaul.
hope this information is helpful
from
AmFix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
Top Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
Ngoro
Are you a Watch Expert? Answer questions, earn points and help others
