Tip & How-To about AT&T CECT Unlocked i68+ Quadband GSM FM Mobile Phone+Free gift Smartphone
Thanks to the author, follow these steps:
GO TO SERVICES AND FOLLOW THE FOLLOWING:
SELECT DATA ACCOUNT
SELECT GPRS
SELECT ANY OF THE PROFILES LISTED(EXAMPLE CHINA MOBILE)
A SCREEN SHOWS ACCOUNT NAME, APN, USER NAME AND MORE
EDIT ACCOUNT NAME TO AT&T, GO ON OPTIONS AND PRESS DONE
EDIT APN EDIT TO wap.cingular (lower case), GO ON OPTIONS AND PRESS DONE.
EDIT USER NAME TO [email protected] (UPPER CASE) AND PRESS DONE.
EDIT PASSWORD TO CINGULAR1 (UPPER CASE) AND PRESS DONE.
EDIT AUTH. TYPE TO SECURE.
SELECT DONE AND IT SHOULD ASK TO SAVE, SELECT YES.
GO BACK A COUPLE OF TIMES UNTIL THE OPTION WAP AND DATA SUPPORT APPEARS AGAIN
SELECT WAP
SELECT SETTINGS
SELECT EDIT PROFILE
SELECT SIM 1 OR SIM 2 (OTHER SIM NEEDS SETUP IF BEING USED ALSO)
IF AT&T APPEARS SELECT IT, IF NOT EDIT ANY PROFILE AND RENAME IT AT&T.
SELECT EDIT PROFILE
GO ON HOMEPAGE AND CHANGE IT TO http://device.home lower case)
GO ON DATA ACCOUNT, THAN GPRS, AND SELECT AT&T.
GO ON CONNECTION TYPE, ITSHOULD READ HTTP, PRESS ON IT, SELECT HTTP
ENTER PROXY ADDRESS 066.209.011.032
ENTER PROXY PORT 8080
PRESS OK THAN SELECT DONE AND IT SHOULD ASK TO SAVE, SELECT YES.
SELECT ACTIVATE PROFILE( ATT WILL APPEAR AS SELECTED)
THE PHONE IS READY. GO TO SERVICES AND SELECT HOMEPAGE FOR INTERNET.
MMS SETTINGS
1. Select Messages
2. Select MMS
3. Select MMS Settings
4. Select Edit Profile
5. Select any profile
6. Choose Edit Profile
7. Edit Rename Profile to AT&T MMS
8. Press Options
9. Press Done or OK
10. Edit Home Page to http://mmsc.cingular.com
11. Press Options
12. Press Done or OK
13. Select ATT MMS and press OK
14.Edit Connection Type to HTTP
15.The IP address is 066.209.011.032 and the port number is 8080 and press OK
16.Edit the Username to [email protected] (UPPERCASE)
17. Press Options
18. Press Done or OK
19.Edit the Password to CINGULAR1 (UPPERCASE)
20. Press Options
21. Press Done or OK
22. Press Done
23. When prompted to SAVE please select Yes
24. Select Activate Profile and yes.
