RCA Universal Remote Code Search
Models RCR312W - RCR311BN - RCR311BIN
RCR311SN - RCR311STN
To setup your RCA Universal Remote Control with your TV or other
devices, you can perform a code search. A code search tries to turn
your set off with different brands' remote control codes until it finds
one that works with your set.
Here are the steps for an RCA Universal Remote Control Code Search:
- Turn on the device you would like to control.
- Press and hold the device key (TV for example).
- While holding the TV key, use your other hand to press and hold the ON/OFF key.
- Wait until the ON/OFF key light comes on and stays on, then release both keys.
- Point the remote at the front of the TV and press PLAY.
- Wait 6 seconds while the remote sends a batch of 10
codes to your TV. If your device turned off, go ahead to the next step.
If the device did not turn off, press play again and wait 6 seconds
again.
- When your device turns off, press the REVERSE key on
the remote and wait 2 seconds. If the device turns back on, press STOP
and your remote is now successfully programmed for controlling that
device. If the device does not turn back on, keep pressing REVERSE
every 2 seconds until your device turns back on. When it does, press
STOP.
I hope that helps.
