Bad pulsar unit
Bad CDI unit
Bad gearbox electrical unit
Bad coil
Bad HT lead or caps
Bad spark plug
Bad earth wires
Bad ignition key switch
Contaminated fuel
Dirty carburetor
AMI (American Megatrends International) BIOS Beep Codes. AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure. BEEP CODE MEANING POSSIBLE CAUSE 1 Beep (No video) Memory refresh failure Bad memory 2 Beeps Memory parity error Bad memory 3 Beeps Base 64K mem failure Bad memory 4 Beeps Timer not operational Bad motherboard 5 Beeps Processor error Bad processor 6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard 7 Beeps Processor exception Bad processor 8 Beeps Video memory error Bad video card or memory 9 Beeps ROM checksum error Bad BIOS 10 Beeps CMOS checksum error Bad motherboard 11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running. BEEP CODE MEANING POSSIBLE CAUSE 1 Long, 2 Short Video adapter failure Bad video adapter Repeating (Endless loop) Memory error Bad memory or bad connection 1 Long, 3 Short Video adapter failure Bad video adapter or memory High freq. beeps (while running) CPU is overheating CPU fan failure Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps. Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
BEEP CODE MEANING POSSIBLE CAUSE 1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard 1 - 1 - 3 CMOS read/write failure Bad motherboard 1 - 1 - 4 BIOS ROM failure Bad BIOS chip 1 - 2 - 1 Timer failure Bad motherboard 1 - 2 - 2 DMA failure Bad motherboard 1 - 2 - 3 DMA failure Bad motherboard 1 - 3 - 1 Memory refresh failure Bad memory 1 - 3 - 2 64K memory failure Bad memory 1 - 3 - 3 64K memory failure Bad memory 1 - 3 - 4 64K memory failure Bad memory 1 - 4 - 1 Address line failure Bad memory 1 - 4 - 2 Parity error Bad memory 1 - 4 - 3 Timer failure Bad motherboard 1 - 4 - 4 NMI port failure Bad motherboard 2 - 1 - 1 64K memory failure Bad memory 2 - 1 - 2 64K memory failure Bad memory 2 - 1 - 3 64K memory failure Bad memory 2 - 1 - 4 64K memory failure Bad memory 2 - 2 - 1 64K memory failure Bad memory 2 - 2 - 2 64K memory failure Bad memory 2 - 2 - 3 64K memory failure Bad memory 2 - 2 - 4 64K memory failure Bad memory 2 - 3 - 1 64K memory failure Bad memory 2 - 3 - 2 64K memory failure Bad memory 2 - 3 - 3 64K memory failure Bad memory 2 - 3 - 4 64K memory failure Bad memory 2 - 4 - 1 64K memory failure Bad memory 2 - 4 - 2 64K memory failure Bad memory 2 - 4 - 4 64K memory failure Bad memory 2 - 4 - 4 64K memory failure Bad memory 3 - 1 - 1 Slave DMA failure Bad motherboard 3 - 1 - 2 Master DMA failure Bad motherboard 3 - 1 - 3 Interrupt controller failure Bad motherboard 3 - 1 -4 Slave IC failure Bad motherboard 3 - 2 -2 Interrupt Controller failure Bad motherboard 3 - 2 - 3 <RESERVED> 3 - 2 - 4 Keyboard control failure Bad motherboard 3 - 3 - 1 CMOS batter failure Bad CMOS battery 3 - 3 - 2 CMOS configuration error Incorrect setting 3 - 3 - 3 <RESERVED> 3 - 3 - 4 Video memory failure Bad video card or memory 3 - 4 - 1 Video init failure Bad video card or memory 4 - 2 - 1 Timer failure Bad motherboard 4 - 2 - 2 CMOS shutdown failure Bad motherboard 4 - 2 - 3 Gate A20 failure Bad motherboard 4 - 2 - 4 Unexpected interrupt Bad processor 4 - 3 - 1 RAM test failure Bad memory 4 - 3 - 3 Timer failure Bad motherboard 4 - 3 - 4 RTC failure Bad motherboard 4 - 4 - 1 Serial port failure Bad motherboard 4 - 4 - 2 Parallel port failure Bad motherboard 4 - 4 - 3 Coprocessor failure Bad motherboard or CPU. 9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
I think the graphics card has become unseated as the PC does not need a monitor to start up so there would be no beeps; Here is a list of beep codes with there meanings. BEEP CODE MEANING POSSIBLE CAUSE 1 Beep (No video) Memory refresh failure Bad memory 2 Beeps Memory parity error Bad memory 3 Beeps Base 64K mem failure Bad memory 4 Beeps Timer not operational Bad motherboard 5 Beeps Processor error Bad processor 6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard 7 Beeps Processor exception Bad processor 8 Beeps Video memory error Bad video card or memory 9 Beeps ROM checksum error Bad BIOS 10 Beeps CMOS checksum error Bad motherboard 11 Beeps Cache memory bad Bad CPU or motherboard
Basic Washer Problems
No fill: Bad water valve kinked hoses unpaid water bill
faulty electronics.
Overfill: trash in water level switch tube bad water valve bad water level switch
faulty electronics.
Washes but don't spin: bad lid switch bad drive coupling or belt bad motor
faulty electronics
Spins pumps but don't wash: bad timer bad motor bad luck
faulty electronics.
Leaks: bad hoses bad pump bad tub gasket
faulty electronics.
Fills washes but never advances: bad lid switch locked up pump bad motor bad timer
faulty electronics.
Goes through complete cycle but clothes soaking wet: bad belt bad pump bad thrust bearing
faulty electronics*.
*electronics in appliances ****. My opinion.
