Tip & How-To about T-Mobile G1 Android HTC Google Smartphone Brown Cell Phone
How to hard reset or factory reset T-Mobile G1 phone
Hard reset or Factory reset will restore the phone back to its factory settings; the way it was when it was first bought or the way it was when it left the factory.
Note that this will erased the entire phone's memory (NOT memory card) and settings to the way it was when it was first bought.
How to hard reset or factory reset T-Mobile G1 phone:
  1. Switch off your G1. *If it won't your phone won't switch off, take out the battery and reinsert it after a few seconds.
  2. Now press the 'Power' key and 'Home' key at the same time and hold it for 20-25 seconds.
  3. Then you will see on your screen a yellow triangle with an exclamation mark in the middle.
  4. After that, press 'Alt+L' key on the QWERTY keyboard (to clean the phone completely).
  5. Next, press 'Alt+W' key (to factory reset it)
  6. Again, press and hold 'Power' key and 'Back' key at the same time for 20-25 seconds.
  7. The reset is complete.
T-Mobile G1 Android HTC Google Smartphone Brown Cell Phone Logo
Need to hard reset my LG.l34c Mobil phone
To hard reset your LG I34c mobile phone, follow below instructions.
Note: Back up all your important and personal data before factory restore. Factory restore will erase all your data and restore device to its original manufacturer settings.
1. Turn the phone off, hold the Home and Volume Down button and then press and hold the Power button too until the device turns on.
2. You will get wipe data / factory reset option
3. With VOLUME buttons select wipe data / factory reset
4. Confirm with Menu key.
GuruAid.com
Dec 19, 2014 | Cell Phones
how open code security factory setting Nokia 5800 Xmusic, Restore all original phone
HARD RESET in Nokia 5800 XpressMusic Smartphone
Please Note:
The result of this process will wipes the entire phone memory and settings fresh to how it was (or should be) when you bought it.You are advise to make a back up of your device and you need to understand that what you are doing this is at your own risk. We will not be held liable for any type of loss that may occur during the reset process.
For Hard Reset;
-Turn the Phone Off
-Press and Hold ANSWER + REJECT + CAMERA keys simultaneously.
- Turn ON the phone by pressing the Power Button
- Wait for the handshake / Nokia logo appears.
FOR SOFT RESET
For Soft Reset;- back to factory settings: This should maintain your data (contacts/messages/calendar/notes etc), just returning your Nokia X6, 5800 XpressMusic back to all previous settings
From menu:
Settings>Phone>>Phone Management>>>Factory Settings
Feb 17, 2011 | Nokia 5800 XpressMusic Smartphone
i forget my nokia 5800 password. pls tell me
Soft Reset The reset will restore all the phone's settings to factory default and delete all user info. You need to use the dialer to enter this code.
*#7370#
Hard Reset Hard reset only works if you had previously updated the phone to v20. Please make backup before applying this type of reset, since it will restore the phone's settings as well as erasing all the data in the phone memory.
  1. Switch off the phone.
  2. Press GREEN + RED + CAMERA + ON simultaneously until you see the "Select Country" option.
Note:
  1. The default password is 12345. You need to press and hold the key until the number appear.
  2. Please do not confuse "revert to factory settings" with soft reset. "Revert to factory settings" can be achieved from Menu > Settings > Phone > Phone mgmt. > Factory settings or *#7870# code, and will only restore the phone to its factory setting without deleting data.
Nov 10, 2010 | Computers & Internet
i forget my password how can i reset it plz send the solution now..
hi im rain im going to give you the code to soft rest your nokia.
-----------------------------------SOFT RESET-----------------------
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
if that does not open your phone you can also try a hard reset.
A hard reset will erase all the user data and restore the phone back to factory settings.
It will erase everything passwords pictures music . But you'll be in and able to set a password of your own. THe hard reset code is.
------------------------------------------Hard Reset-----------------------------------
It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
Enter the code: *#7370# and press Yes to confirm initialization.
Important Notice: It is recommended that you save all important information on your phone IF it can't be replaced.
Nov 17, 2009 | Nokia 1100
1,515 people viewed this tip
Top T-Mobile Cell Phones Experts
Ekse
Trimesh
Steve Allison
Steve Allison
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
