Since your wireless is working, the missing driver is for your ethernet port. Go to gateway support driver download (link below). Select your computer by following the on screen prompts and download the driver for you LAN port.
You want to try and see if there is a driver update for the ethernet controller. Go to: START> RIGHT CLICK "MY COMPUTER"> then PROPERTIES> DEVICE MANAGER> NETWORKING> ETHERNET PORT. You can roll-back the driver or you can try to update the ethernet driver using Windows Update Program. Make sure the driver is located in the device manager system and windows recognizes it. Your Ethernet Controller is a discontinued product. If you can't seem to get the ethernet controller to work and don't have the Floppy Disk Driver for it, then I suggest replacing it with a new stand alone ethernet controller that uses PCI or PCI-E ports. You can find some at Best Buy and Staples. They are easy to install and they don't use your motherboard memory and are not integrated on motherboard. I hope you find something that works and you can get back online again.
I work for Lenovo and I know the website where you can get all the drivers for your system. Click Here. Click on "I Agree" then click on either "Run" or "Save File".
The driver above is for the Realtek Ethernet controller. If that does not work then it means that your Ethernet controller is Intel, you can get it HERE.
first check for all the drivers in the device manager....
if every thing is perfect in driver side, then check if the ethernet/ lan is enabled....
then check is the light in the ethernet adapter is lit, when you plug any ethenet cable in it...
still if it is not working, then finally try to update the latest driver for the ethernet controller....
if nothing works, then buy an pci ethernet card and use it.....
you can also buy external cards like usb to ethernet converter...
even belkin manufactures usb to ethernet controller....
If i's definately the controller not working then make sure its enabled in the Bios and that Windows (?) hasn't turned it off in Device Manager.
If all else fails then get an cheap ethernet card
