Tip & How-To about Computers & Internet
Create shortcut icon for shutdown and restart on desktop
For easy usage you can now create icon for shutdown and restart on desktop. Right click on desktop in that do to new and then select shortcut. Now you will get create shortcut window will appear. I this you will see one text box for select the location of the item. In that place you need to write "shutdown -s -t 00" without double quotes. and click next. Here you will find the option t rename that icon. after that click on finish.your shortcut is ready on your desktop. This icon for shutdown. If you want to create icon for restart.Follow the same steps above and in the of location of item write "shutdown -r -t 00" without double quotes..
Computers & Internet Logo
How to Create a Shutdown Icon on my Desktop?
Just create shortcuts for both actions using the following steps: Step 1: Go toDesktop and Right Click then go new and Click Shortcut menu. Step 3: Change the Setup Icon Go to Shutdown Button Properties then click Change Icon and Choose your Icon Done. Step 4: Right click the shortcut and select Pin to Start
Oct 18, 2016 | Computers & Internet
my laptop acer aspire5920 is not shutting down due to removal of my shutdown file from my laptop due to unknown reasons.
Hi dear,
Create Icons for Shutdown and Reboot If you find it annoying to access the Start Menu for shutting down or rebooting the computer, create a shutdown and reboot icon for the desktop.
Desktop Shutdown Icon Right click on the desktop
Click [New] [Shortcut] to open the Create Shortcut Wizard
Type [shutdown -s -t 00] without the brackets.
Click [Next] and type a descriptive name of your choosing for the shortcut
Click [Finish]
Add a bit of class to the shortcut by assigning it a custom icon. Right click the shortcut, click [Properties] and select the [Shortcut] tab. Click [Change Icon] and select from the icons that are displayed.
Desktop Reboot Icon Right click on the desktop
Type [shutdown -r -t 00] without the brackets.
Click [Finish]
A Final Note: If you happen to be as fanatical as I am about having nothing on the desktop, drag the new icons into the Quick Launch area of the Taskbar.
then use it.
if not resolve it
then use following step ;-
click on start then go to RUN and type SFC /SCANNOW
press enter
this command recover all windows lost files, if it will ask windows CD then enter the windows disk.
bye take care
good luck
veeru
May 07, 2009 | Acer Aspire 5920 Notebook PC
My computer does not shut down
Ok
Gonna try and teach you some basic programming :-).
What the following will do, is create you a Desktop Shutdown Icon, which when you double click on it, will hopefully shut down your PC rather then restart it.
So here's how to do it :-).
1. Right click on your desktop and select new > shortcut.
2. In dialog box type “shutdown –s”
3. Click next to continue and then type a name for shortcut (IE Shut Down PC) and click finish.
Now you should see the shortcut on your desktop and will hopefully solve your problem.
Dec 08, 2008 | Computers & Internet
249 people viewed this tip
Alun Cox
