Tip & How-To about Frigidaire Affinity ATF8000FE
Unclog your washing machine pump.
This is a tip for those who own a Frigidaire ATF8000 washing machine model which does not drain properly and/or makes a loud noise while draining.
For me, it was something caught at the end of the hose trying to get into the pump. This made a terrible loud noise when the washer was in spin cycle, working the pump to try to drain the water.
First of all, unplug the power cord.
Since the new Frigidaire ATF8000 models have no easy access panel to remove in the front, you have to unscrew the back panel to begin.
I found that I could not do anything except unplug the two wires clipped to the pump from the back of the machine, since the Askoll M85 pump is located near the front.
So I carefully laid the washing machine on one of it's sides so that I could get to the pump from the opening on the bottom of the washer.
This was easiest since now I have two ways of seeing the pump. But it still would be better if Frigidaire didn't block access from the front.
So now you should be able to move the green metal clip holding the big black hose that comes down from the drum attached to the pump. There will be water spilling out as you remove the hose. I put some dish towels underneath to catch anything.
In my case, as soon as I unattached the black hose, I found a piece of metal bra wire halfway into the pump. I removed this, re-attached the hose, raised the washer back upright, re-attached the two wires clipped to the pump, screwed on the back panel and plugged the washer back in.
And now the machine works beautifully once again.
Hope this helps.
Frigidaire Affinity ATF8000FE Logo
frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 22, 2011 | Frigidaire ATF6000ES Front Load Washer
Hello, Frigidaire washer will not drain, its not clogged. makes loud humming noise when it should drain.
The drain pump has gone bad , it probably has a broken impeller. These units require you to remove the back panel to replace the drain pump assy.
Dec 03, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer LTF2940FE0 wont drain
That loud noise is most likely debris bouncing around inside your water pump. Pull the 2 hoses off and try removing it by hand, or un-bolt it from the floor pan and tip it sideways to shake any small objects out. I found a mans wedding ring in there once.
Mar 18, 2010 | Frigidaire ATF6000ES Front Load Washer
water draining makes loud noises
if water isn't draining properly the cycle will stop thereon check the drain pipe
Oct 12, 2009 | Washing Machines
4,882 people viewed this tip
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
