Tip & How-To about Computers & Internet
Do you have a computer keyboard that has keys where the print is no longer on the top of the keys because it is worn out?
I did and I need to see the keys I type on so worn out lettering is unacceptable.
I tried all sorts of things including purchasing stick on letters. All worked for a short time and then I was back to the same problem.
Here is how to best solve this problem.
Buy a P-Touch label maker. Set the size of the print to whatever you want to be close to the size of other letters showing on the keyboard.
Have the label maker print out the separate letters you need. Then cover the letters with scotch tape to have another barrier on top of the letter you just printed. Cut the tape with a scissors into a square to properly sit on the proper key. Peel off the sticky back of that label and mount it. It will last a good long time and you can make as many new ones as you may need.
