Tip & How-To about Miscellaneous
It wont come Apart.
Don't force it. If it does not come apart easily then you have missed something and is worth rechecking.
Miscellaneous Logo
I accidently dropped my mp3 player in the bath, it is now dead, doing nothing, can it be revived? Many thanks.
Hi santhosam123
Chances are its toast, but it is worth a try...sometimes it works
If you ever find that you have to deal with a wet device, don\'t just abandon it.
Instead, try the following method to repair the water damage:
DO NOT TURN IT ON!
Take it apart as much as you can. Take out the battery, the memory card and whatever else can be easily disassembled. (Just make sure you can put it back together.)
Store the parts in an air-tight container covered with either dry rice, silica gel packets or kitty litter. These will absorb the moisture from your electronics device, leaving it water-free.
If no rice, gel packets or kitty litter are available, try using a vacuum to suck the water out.
DO NOT blow-dry the parts, it will only force the water farther in and cause more damage.
Please take time to rate me.
Bud
i washed my mp3
Hi stantheman10
If you ever find that you have to deal with a wet device, don't just abandon it.
DO NOT TURN IT ON!
If no rice, gel packets or kitty litter are available, try using a vacuum to **** the water out.
The radio and the clock have just gone blank in my 2008 swift.
There's no way to easily check what's causing your power problem. You may have a short in your 'hot wire' or the red wire coming out of your radio (I'm assuming the ground wire hasn't come loose and shorted out the radio, but that is something to consider also....as long as you don't smell something burning you should be ok). The problem with newer vehicles is that the radios have been made 'theft proof' by forcing you to remove pretty much the entire dash to get at them. Unless you or someone you know is mechanically inclined, I'd suggest taking it to a garage...sorry.... :(
How do I remove the shredder head case of an Aurora AS890C? I have removed the 6 screws (it's unplugged), but it still won't come apart. It quit working, so I don't know if it's jammed or if I have to change the fuse.
There are 7 screws. You missed the one hidden under the small silver label.
Once you take it apart, don't waste your time calling Aurora as you voided your warranty and ability to get help from them. That happened to me.
Top Miscellaneous Experts
H Smith
Level 1 Expert
Robert
vince
Are you a Miscellaneous Expert? Answer questions, earn points and help others
