Tip & How-To about Magimix 3100 1057 Cups Food Processor
The handle of a magi mix cannot be removed. This how you can clean the muck out of the handle.
There are two openings at the top of the handle. One next to the bowl and the other is at the top of the handle grip. Pour dishwashing liquid (as much as possible) into the two openings. You will see it flowing into the handle.
Then you will need a 'K'archer (or similar) water blaster. Direct the jet into the two openings. This should be done with the jet almost in contact with the handle to achieve maximum pressure. The dirt will start to come out. Repeat this cleaning operation with the dishwashing liquid and water jet (perhaps 5 times) until the handle interior is clean. There are 4 small drain holes on the sides of the handle into which dish washing liquid can be poured and jetted out.
I know this method works, as I have done it successfully on my wife's Magimix!
Des Pollard
Cape Town, South Africa. 12 March 2019
