Tip & How-To about Miscellaneous
Google Home Speaker Microphone
After many months of enjoyable use of my Google Home Speaker it suddenly stopped responding.
I had changed modem and router and so I had a new WiFi setup and I thought that was the culprit, but resetting the Google Home Speaker by pressing and holding the Mic button for a long time did not fix the problem.
I used Netgear Genie to make certain my Speaker was recognized on my Network.
I then spent a long time on the Internet, searching Google's website for answers.
Finally I called Google and a Tech there talked me through a couple procedures.
But none of them worked either.
I was getting music I wanted to play on the Speaker to play on my cell phone, so I knew the connection with Google Music was good.
I could not find anything on the Web about how to take the speaker apart, to see if there was a bad microphone connection or something visible I could repair.
I had used the Google Home Speaker for a long time, and just as a last effort I put some 91 percent rubbing alcohol on a Q-tip and gently wiped the 2 microphone openings (Yellow arrows).
A significant amount of lint was present on the Q-tip.
I swiped both openings one more time with alcohol using the Q-tip.
The speaker starting working again, perfectly.
I hope this helps someone as frustrated as I was.
Miscellaneous Logo
How do I set up my google home to my new wifi?
It appears you connect it from the phone app:
I can't establish a Wi-Fi connection If you're able to see your Wi-Fi network listed in the Google Home app during setup, but you can't connect your Google Home device to the network and complete the setup process, try these steps. Initial checklist
  1. The Google Home device is powered on and plugged into a wall outlet.
  2. Make sure you're using the correct password. Try re-entering it again.
  3. On your mobile setup device, make sure:
  4. Make sure the Google Home device is within 15-20 ft (4-6 m) from the Wi-Fi router.
  5. Has the Google Home been connected to this network before?
    • Were there any recent changes to your network?
      • Did your ISP (Internet Service Provider) upgrade or make any changes to your router/modem?
Apr 28, 2018 | Google Computers & Internet
I want to change my wifi password
Important: Your WiFi password can also be known as a WPA Pre-Shared Key. Type http://192.168.0.1 in your browser bar while connected to your WiFi-enabled Internet modem (either directly or via WiFi). Enter the username and passcode to get into the settings of your WiFi-enabled Internet modem.
How do I change my Home WiFi settings, including network name ...
https://www.timewarnercable.com/.../homewifi/how-do-i-change-my-wifi-settings1.html
How to Change Your Wi Fi Password: 7 Steps (with Pictures)
https://www.wikihow.com/Change-Your-Wi-Fi-Password
Steps. Open your router's configuration page. Enter your router's username and password. Open the Wireless section. Change the password. Check out your security type. Change your network name. Save your settings.
https://www.timewarnercable.com/.../homewifi/how-do-i-change-my-wifi-settings1.ht... Important: Your WiFi password can also be known as a WPA Pre-Shared Key. Type http://192.168.0.1 in your browser bar while connected to your WiFi-enabled Internet modem (either directly or via WiFi). Enter the username and passcode to get into the settings of your WiFi-enabled Internet modem.
How do I change my NETGEAR router password or network name ...
https://kb.netgear.com/.../How-do-I-change-my-NETGEAR-router-WiFi-password-or-... Mar 16, 2017 - To change your WiFi password or network name (SSID): Launch an Internet browser and type http://www.routerlogin.net into the address bar. Enter the router user name and password when prompted. The default user name is admin. The default password is password. Click OK. The BASIC Home page ...
View and Change Your WiFi Password - Xfinity
https://www.xfinity.com/support/articles/view-change-wifi-password Jump to View and Change Your WiFi Information Online with My Account - Click WiFi Network & Password. Scroll down to WiFi network & Password and click Edit. From here you can change your WiFi network's name and password. Note: This online tool supports all current Xfinity Wireless Gateway ...
and also videos
change my wifi password Google Search
Apr 03, 2018 | Computers & Internet
I'm getting an Error code 51030 when I'm trying to make a wifi connection on my wii console
Error Code: 51030
Unable to connect to your wireless network
Likely cause: Your wireless router may need to be power cycled, or the connection settings have changed.
How to fix: Power cycle your router; redo the connection settings on the Wii and try again.
  • Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this, unplug both the modem and the router from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii, Nintendo DS, or Nintendo 3DS online and test for proper response.
  • Erase your old connection settings on the Wii and set up a new one, as your router's settings may have changed since you last connected.
Jun 05, 2011 | Nintendo Wii Console
144 people viewed this tip
Top Miscellaneous Experts
Bill DeLisi
Bill DeLisi
Rachael Newton
Rachael Newton
Level 1 Expert
Roger Goldberger
Roger Goldberger
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
