Tip & How-To about Seiko Kinetic watch
Replacing the Battery/Capacitor of a Seiko Kinetic watch
There are some articles and videos circulating recently about replacing a Seiko Kinetic Capacitor with a common Silver Oxide battery, the type used in common watches.
In a word: Don't.
I have replaced over 200 Seiko Kinetic Capacitors (sometimes mistakenly referred to as a "battery") and am very comfortable discussing the right way to get a Kinetic running correctly, versus the wrong way.
Can you remove the Kinetic's rotor and put in a Silver Oxide battery the same size as the previous Capacitor and your watch will work? Possibly.
Will you install the new battery upside-down? Very likely.l
If you touch any of the vital contacts inside the watch with the battery will it fry your watch? Possibly.
Will the watch overheat or burn? Possibly. Typical batteries don't have the inner chemical makeup of a Lithium-Titanium Capacitor.
Is the pendulum that is weighted and designed to turn the rotor going to be negatively affected? Probably.
The cost of a correct Seiko Kinetic Capacitor has dropped dramatically, reputable sources like Amazon now sell genuine Seiko Capacitor kits for about 20 dollars.
Why risk a 400 dollar watch to save 10 dollars on a battery.
Let me know if you have any general questions about Seiko Kinetic Capacitors and/or Batteries.
There is a lot of inaccurate information floating around, which can be expensive.
Seiko Kinetic watch Logo
2answers
my watch runs too fast: adds appr. 1 minute every 24 hours
That is way too fast for a Seiko Kinetic. There is no adjustment to slow it down. With time of course it might run slower as the gears get dirty. Maybe Seiko will replace the movement, worth asking
3answers
My seiko kenetic watch stopped, and will not say wound
I thing required cleaning for the movement and new capacitor.
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
2answers
Seiko Kinetic Watch model 8D0557
For sure it is time to replace that old capacitor and replace it with the latest solution that uses a Lithium Ion battery. Find a good experienced repair person to do this for you. I do this daily and I am a Certified Master Horologist/watch repairman.. Ron at TimelyWatchRepair.com
3answers
Seiko Kinetic that doesn't work
This watch does not have a battery, but has a capacitor which is rechargable. It is not taking a charge, and needs to be replaced. You should take it to a store with a watchmaker ON THE PREMISES. Or you could send it to: www.bscwatchrepair.com
Top Seiko Watches Experts
Paul Bade
Ngoro
Are you a Seiko Watch Expert? Answer questions, earn points and help others
