Tip & How-To about Sunfire True Sub MK II Subwoofer
Sunfire Mk2 hum repair tips
Take a look at my video to get an idea of how to open the Sunfire MK2 properly and also get an idea what sort of dangers live inside the box. There are several fixes that have worked for me in the past and one that is not working now.
https://youtu.be/EHX86byhY9A
Sunfire True Sub MK II Subwoofer Logo
Trying to remove a Whitco mk2 lock barrel. Needs to be in lock position but can't seem to lock while the door is open. The key won't turn while door is open. Any ideas.
There's a secondary latch above the main latch that needs to come in contact with the striker plate in order to lock the door. If you press it in while using the key, it will allow the key barrel to fully rotate. Here's a video demonstration -
How to replace barrel on Whitco MK2 tasman screen door lock
Sep 07, 2018 | Cars & Trucks
Is it dangerous for a king snake to be out in the open at night, it's 88 degrees right now, low will be 68 tonight. I think it's injured.
snakes can hunt at night or if the temp is too cold they hibernate until the weather gets warmer
snakes live in the open and are well capable of looking after themselves
tey should only be handled by professional snake handles especially injured snakes as they are very dangerous if injured
Sep 09, 2015 | Heating & Cooling
auto repair what does fuel volume regulator control circuit open mean would it be a flange?
Buy yourself a auto fault meter that you plug in the port inside the car. You will find this will put out any warning lkights that are not dangerous and will identify any that need attention.
Jul 21, 2014 | 2002 Pontiac Sunfire
pontiac sunfire 2005, bar from the trunk fell off
they are usually a combination of bars one over the other and sort of spring loaded and locked by clamps you may have to go to what we in Canada call an auto wreckers and see if you can buy the whole assembly and replace it., all the bars if locked in place properly will open the trunk and hold it open until you press or push it closed
Dec 20, 2009 | 2005 Pontiac Sunfire
457 people viewed this tip
Top Sunfire Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Are you a Sunfire Audio Player and Recorder Expert? Answer questions, earn points and help others
