Tip & How-To about Washing Machines
I had a LG front load washing Machine developed a UE Fault. Shocks Pump and drainage good and bearings good. Machine not out of balance.
Everything I looked at for a balance sensor did not provide the answer. Some even suggested the Hall sensor. This senses the drum rotation via a magnetic field similar to car ignition.
The Balance is sensor is part of the water level switch. The water level sensor and bottle at hose was cleared yet the fault continued.
Changed the water pressure switch all fixed and working perfect.
There must be some kind of sensor in the water pressure switch, sloshing and causing the sensor to trip or perhaps the sensor went to sensitive?
