Tip & How-To about Apple Ipad I-pad
Using an alias email with GMail in iOS 10 (iPad and iPhone)
A relative using an iPad (iOS 10) wanted to use an alias e-mail with his GMail account but iOS 10 appears to have removed the functionality which is still available in macOS. A solution is suggested at on the Apple discussions pages
(Creating email alias in iOS 10 no longer possible ) but here I give step-by-step details (I don't have an Apple ID so I couldn't post this in the Apple discussions forum)
Preliminaries: I'm assuming the user has a gmail address [email protected] with password pwd1 and 2-step-authentication enabled in GMail (have your mobile with you!) The user wants the sent e-mails to appear to come from [email protected]
The process involves setting up the GMail account twice on the iPad:
  1. once using the iPad built-in GMail setup, for Calendar, Contacts
  2. once using the iPad Other mail service setup, for Mail
1. In Settings go to Mail, add an Account; select GMail and follow the prompts... this sets up Mail to use GMail mail, calendars and contacts (and optionally to stored Apple Notes on GMail) for [email protected]. Later on we will switch off mail as it will be duplicated by the following IMAP account.
2. In Settings go to Mail, add an Account; this time select Other as the mail provider:
a) Fill in the dialog entries:
Name: the user's name;
Email
: [email protected]
Password: get this password from Google using App password feature (Sign in using App Passwords -- note you will need your mobile; this is a 16-character password) and write it down as you will need it again later;
Description: you can call this GMail mail only for now
b) Click Next and enter the following information
Name: should be prepopulated as above
Email: should be prepopulated as above [email protected]
Description:
should be prepopulated as above GMail mail only
Incoming mail server (as per Read Gmail messages on other email clients using IMAP):
Host name: imap.gmail.com
Username: user.name
Password
: the 16-character password generated by GMail App password above
Outgoing mail server (as per Read Gmail messages on other email clients using IMAP):
Host name: smtp.gmail.com
Username: user.name
Password:
Use SSL: yes
Authentication: password
Server port: 587
After entering all this information, Mail should connect to GMail and verify the credentials; if correct, it will show blue ticks against the Email, Incoming and Outgoing details. If not then it will display a message saying it could not use the credentials.
After doing this, you should have two accounts (in addition to a possible iCloud email account): GMail and GMail mail only; GMail handles Contacts, Calendars and GMail mail only for Mail only. You can check this and then rename GMail mail only to GMail as Mail accepts two accounts with the same name.
Now if you want to write an e-mail which appears to come from [email protected] you can select that as the From address: either in the e-mail itself if you have multiple e-mail accounts, or in the Composing settings of Mail.
Test this by sending a couple of e-mails.
Note: if you have an iCloud account, when that is the current inbox in Mail, new emails will be sent with the iCloud. When the GMail account is the current inbox in Mail, the new emails should be sent with [email protected] if set up that way.
HTH someone... until the next iOS or GMail change breaks something else ;-o
Apple Ipad I-pad Logo
2answers
How can I resset my iCloud? I put a wrong email so now it won't verify my account
You can always restore it to brand new.
You need a computer with iTunes and the charghing usb cable.
Before restoring make sure that the Find my iPhone app is off, otherwise after restoring it will give you the very same wrong email.
Once that is off, connect the ipad to the computer and click restore.
Once restore is complete, at very end you will be prompt with 2 questions:
1. Set iPad as brand new
2. Restore from (your name) back up.
At this iem you can choose either one, because Find my iPhone is off. And now you can change the email address.
It is your best option since it is way too difficult without restoring it.
I just got an ipad 3 and when I try to set up gmail account it does not show gmail as an option in the list
- first update the iPad to the newest iOS system (8.2.1) then Gmail should appear in the selection window.
you can do it as follows:
Best is to connect the iPad with an USB-cable to a computer and open iTunes software. there you will see your iPad showing up and you can do an update to iOS 8:
just-got-ipad-3-when-try-set-up-gmail-of1o0fkyrymqaiqlgkygvvrr-2-0.jpg just-got-ipad-3-when-try-set-up-gmail-of1o0fkyrymqaiqlgkygvvrr-2-2.jpg just-got-ipad-3-when-try-set-up-gmail-of1o0fkyrymqaiqlgkygvvrr-2-9.jpg iOS Apple iPad iPhone iPod Email Setup
i want to remove a google account from my computer
For PC:
Unless you have installed extra items like Google Drive or Affixa, or for Windows 8 App, Google Gmail is a web application and is not installed on your computer so there is nothing to remove, just don't go to the site or login under Chrome. If you have installed a Gmail program, you can go to Control Panel, Programs, select the application and click at the top of the window Uninstall.
For IOS, press on the Gmail Icon for a few seconds, when it starts moving tap and the option to delete will appear.
For IOS Mail application, under Settings; Mail, Contacts, Calendars; select the Gmail account, then you should get a Delete option.
My son bought my iPad in Australia and he set up his email account on it before he gave it to me. Now when I want update thinks like Skype it will not let me because my sons email keeps coming up and i dont know his password I want to delete and use mine all of the time
You don't have to delete his account. It is simply the "default." If you setup your own mail account, you can then make your account the default. You will afterwards set up your own Skype account using your own email address. Nothing stops you from setting up a Gmail (Google) account. If you don't know how, simply google "how to set up a google email account." As to how to make that the default account on your iPad, where the menu item is to do that may depend upon the version of the operating system. Here is one depicted instruction set:
How do change my default Mail account on iOS 10 or you might find the following of use:
How to Set up Email on an iPad
ipad will not get my e-mail from my gmail account
for ios 4.0 or newer
To configure the 'Mail' app on an Apple device for access to Gmail, just follow these steps:
  1. Make sure you've enabled IMAP in your main Gmail settings
  2. Open the Settings app on your device
  3. Tap Mail, Contacts, Calendars
  4. Tap Add Account...
  5. Tap Gmail
  6. Enter your account information, being sure to use your full Gmail address, including '@gmail.com'
  7. Tap Next
  8. Tap Save
And you're done. You can add additional Gmail accounts by repeating the same steps above.
http://mail.google.com/support/bin/answer.py?answer=184972
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
