Try unplugging as suggested. Also, try different inputs (HDMI, component, etc.) and different cables to be sure it's not some external item causing problems or just one input. Also plug it into an outlet on a different circuit in your house.
If everything you try still shows the lines, it's probably the screen itself and is too expensive to fix.
Check and replace damaged component/s at its main power regulator board, or, replace the board as card basis. If you wish to get more details, check this link.http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in thebrand name and model number to of your set, to its search box, and
press 'Enter' or view it in Mosaic / Timeslide
option.
