Tip & How-To about Amana Kitchen Ranges
1. BUY A 1/2" TO 1" WIDE WHITE PLASTIC FLAT STRIP ABOUT 2 MM OR 1/8" OR LESS THICK. OR BUY ANY PLASTIC STRIP AND CUT DOWN TO SIZE AS ABOVE.
AT THE BASE OF MY SHOWER WHERE THE BASE UNIT CONNECTS TO THE TILES THERE WAS A UNSIGHTLY SILICONE SEAL.
I GOT A LENGTH OF WALL CABLE CAPPING /WHITE AND CUT IT INTO 1" WIDE FLAT STRIPS OR YOU CAN PURCHASE FLAT PLASTIC STRIPS NORMALLY A COUPLE OF METRES LONG FROM YOUR LOCAL DO IT ALL SUPPLIER , CLEAN AND DRY OLD SEAL USING A HAIR DRYER ,
CUT ONE LENGTH AT A TIME, REMEMBERING TO ANGLE CONNECTING CORNERS, USE FRESH SILICONE TO RUN ALONG WHERE OLD SILICONE IS
PLENTY TO FILL IN GAP , NOW FIT PLASTIC STRIP AT A ANGLE ACROSS TILE AN BASE UNIT ,PUSH IN UNTIL SILICONE STARTS TO SEEP OUT OF EDGES, WIPE WITH A WET CLOTH TO REMOVE ANY SILICONE,
SO YOU END UP WITH A EASY TO CLEAN PLASTIC SEAL ANGLED AS /l AROUND BASE OF SHOWER.
WITH NO SILICONE IN SITE TO DISCOLOR. ALSO WORK TOPS TO TILES CUT SMALL STRIPS SAY 3/8" TO 1/2" WIDE ANY COLOUR. FIT AS ABOVE.
