Tip & How-To about Leviton 8599 GFCI Receptacle
GFCI wont RESET
Unplug everyting that's plugged in to all the outlets on that circuit (which that GFCI controls), and then press the RESET button. It should work.
If NOT, unplug it all as above, and then disconnect each receptacle. (be careful that no power is being sent to any of them and that noone touches the wires because it will start working after this). then reconnect the GFCI receptacle only and see if you can press the RESET button then. if so, then you know one of the outlets on that circuit has an issue. connect them each one by one and test if you can reset after each one. If you can, then you know which receptacle it is. try reconnecting that one again,there's a good chance it will work as you have just tightened the wires. if not, then you have a more serious problem, possibly a short somewhere in the wall.
i'm not an electrician, but i just had this problem and this tip was passed on to me by a friend and it worked.
Leviton 8599 GFCI Receptacle Logo
My food disposer has no sound I need help. Could you help me?
If you open the cabinet door under the sink, you should be able to see the disposer motor. On the bottom or side, there should be a small bump that is the reset button. Push the button in and it should work again.
If it still does not work, make sure that the power cord is plugged into the outlet.
Still not working? Check the fusebox for a blown fuse or tripped circuit breaker.
One last idea: if the outlet that the disposal is plugged into is a GFCI protected plug, there will be a TEST and RESET button in the center of the outlet. Unplug the disposal cord, press the RESET button on the outlet, then plug the disposal cord back in.
Aug 31, 2015 | Food Mixers
Bunn GRX-B won't heat and yes it is plugged in and vacation switch is on
You said "...turned vacation switch back on". In fact, it should be turned off for normal use.
If that's not the problem, and it's plugged into a GFCI outlet, press the RESET button (do not press the "test" button).
If still no joy, plug something else into that outlet to see if it works. If it doesn't, check the circuit breaker for that outllet.
Jul 14, 2014 | Bunn GRX-B
why is my bunn coffee maker water not heating up?
Make sure it's getting power, and that the "vacation" switch isn't on.
If on a GFCI outlet, press the RESET button - Do Not press the "test" button. If GFCI is located on the breaker or another outlet (not uncommon), try resetting the breaker or that other outlet.
If still no joy, check that the outlet is hot by plugging something else into it. If that item doesn't work either check the circuit breaker for that outlet by moving the lever all the way to the Off position, then back to the On position. You should hear a click like a light switch.
Apr 27, 2014 | Bunn Coffee Makers & Espresso Machines
Water runs through it imemediately before it heats up.
If on a GFCI outlet, press the RESET button - Do Not press the "test" button. If GFCI is located upstream on the breaker or another outlet (not uncommon), try resetting the breaker or that other outlet.
Apr 21, 2014 | Bunn Coffee Makers & Espresso Machines
MY JETS WONT TURN ON
The threaded knob should not be related to the problem, it just controls how much air gets mixed into the water jets. One possibility is that the electricity is off. These tubs should receive power through a Ground Fault Circuit Interrupter (GFCI) type of circuit breaker for your protection from electrical shock. Check your circuit breaker panel(s) for a breaker with a little square white or yellow "test" button. Refer to the label (if it is there) to see if it refers to "tub" or "spa" or "bath" or something like that. You may have to turn the breaker handle off (push extra hard to make it reset) and then back on again. If the breaker handle is in the "on" position and the "test" button does not "trip it off," call an electrician. If no luck there, check the bathroom for an electrical outlet with GFCI protection, again looking for white or yellow (or red) buttons - one should be engraved "test" and the other "reset" as the electrician (I hope it was an electrician) may have supplied the tub from this outlet (not actually up to code). Plug an appliance or light into the outlet. If it doesn't work, push the reset button on the outlet and test again. If working, now test the spa. If that doesn't work, test every other GFCI outlet you can find - in the kitchen, other baths, garage, outdoors, basement, etc. using the same testing procedure. If you find a GFCI breaker or outlet "tripped" that restores the tub, that indicates there is something wrong with your electrical system that could cause you to get electrocuted, and requires that you hire a qualified electrician to investigate the problem. The same is true for any GFCI outlet that does not "trip" and/or "reset." If this doesn't fix the tub, the problem may not be electrical but some other problem with the system, indicating a plumber or spa tech may need to be consulted. Note: these GFCI breakers and outlets are supposed to be tested and reset once every month. How many of us do that? Well, at least as often as we test our smoke detectors, I suppose.
May 20, 2013 | Home
463 people viewed this tip
Top Leviton Electrical Supplies Experts
jdthefixer
Gene Haynes
boomanfoo
Level 1 Expert
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
