Tip & How-To about Apple iPad Tablets & eReaders
How to unblock sites in iPad or iPhone
The most secure and reliable way to open blocked sites in iPad or iPhone is using vpn. You do not need any specific application for this. You can simple make a new vpn connection on your iOS device with standard iOS features.
All you need is setup vpn connection following simple steps below:
To make a new vpn connection in your iOS device you need to do the next:
  1. Go to Settings > General > VPN
  2. Click Add VPN Configuration
  3. Choose PPTP VPN and enter you VPN account data. You will receive your VPN server, username and password in the e-mail
    Server address must be exactly as in your account data (without http://, www or any other symbols)
  4. Save your VPN configuration. Once you have created VPN connection you can switch it ON and OFF on the main settings screen
Once you have created vpn connection you can switch it on and off on the main settings screen.
Under the vpn connection you can access any blocked website and be absolutely sure that you are safe and secure.
Sahrzad VPN How to Setup Guides
Tablets & eReaders Logo
4answers
Retrieve lost contacts on my ipad
Do you have backups on iTunes or iCloud? If not, you may need a professional iPhone contact recovery program on your computer.
How to Recover Deleted or Lost Contacts from iPad
10answers
How to delete VPN from my iPad
To delete vpn from you ipad you can simple go to Settings > General > VPN. Here you will see all the vpn connections created on your device. Here you can delete it. You can review detailed instructions here: Sahrzad VPN How to Setup Guides
2answers
i cant get my yahoo mail because my i pad will not connect to my wifi
If your wi fi will not connect then you need to get that sorted before you are able to get your mail. To do this I suggest turning the iPad off and go and unplug your router - the one connected to your computer from the wall for 5-10 minutes. Go back and plug it back in and that will power cycle it. Once you have done this go back to the iPad - Tap Settings > then Network >tap the wifi button and slide to on > then select your network and you will need your password.
Once you have done all of that you should be able to connect.
Let me know how it goes.
For step by step video guides for the iPad covering all features head over to >> http://www.tabletmastered.com/blog/
problems transfering apps from iphone to Ipade
You are able to use any appstore app with the iPad. Make sure your iPad is listed as a connected device in the left side bar of iTunes. Check your sync settings to make sure they're set to sync with your iPad and if needed restore your iPad using the restore button and try to sync again.
To make an application fullscreeen tap the small "2x" button in the bottom corner of your iPad. This will upscale the app to fullscreen.
Hope this helps, if you found this helpful please leave some feedback. Thanks.
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
