Tip & How-To about Razor E100 Electric Scooter
How to extend the battery life of Razor Scooter Batteries
You can extend the life of your scooter's battery if you take proper care of it. Most people report trouble in getting more than a year or two out of their razor scooter battery set. This is actually a common problem with vehicle batteries.
  • Keep your battery charged
It is recommended to keep your battery fully charged to avoid the build-up of sulfate-ion inside it. Sulfate-ion accumulates when the battery is in a discharged state for a long time.This is the most common reason of premature depletion of lead acid batteries. This can be easily avoided if the scooter battery is kept in a constantly charged state.
  • Charge you Razor Scooter Battery during the Off-Season
Even if not used Sealed Lead Acid Batteries will self discharge over long periods. This will leave the battery in a not fully charges state which will enable the sulfate-ions to build up inside the internal plates which will slowly deplete the battery's capacity. In order to prevent that, you should charge the razor scooter battery at least once every three months when it is not in service.
  • Use a Battery Tender
Battery Tender chargers are a great way extend the life of your SLA batteries as they are designed to fully charge and maintain a battery at proper storage voltage without the damaging effects caused by trickle chargers.
References:
Battery Maintenance 101 How to Extend Battery Life of Razor Scooter...
BU 804b Sulfation and How to Prevent it
Deltran Battery Tender
Razor E100 Electric Scooter Logo
Any tips on extending the life of a Macbook Pro battery?
My suggestion would be to buy a new battery.
After that you should shut down your computer at night (or every other night) and make sure you don't leave it plugged in for a long time (only charge until it is 100% then unplug).
These are two of the most important things towards ensuring significant battery life.
Hope that helps!
Dec 13, 2011 | Apple MacBook Pro Laptop Computer with...
dell axim x51v main battery low message. It has been ont he charger and I have the extended battery. How do I fix this?
Check to see that it is in fact charging. If the power button light stays amber and never goes green, it could be battery, PDA or charger. If you do get a green, that pretty rules out charger/cradle. If the extended battery isn't an ORIGINAL Dell, and is more than a year old, it's likely the battery. 2 quick checks: 1) Try a standard life battery. If you get exaclty the same result, your Dell's got issues. Might only need a firmware re flash. But if your going to do it, I recomend going to the LennySH WM6.1, it's faster, more stable, cool battery indicator & other goodies. 2)See if the battery is bulging; if it is, it's time is near. There seems to be a real problem with the eBay'ish extended batteries. On the other hand, I've heard a few guys report ok battery life, and just a low *reading*. Dell batts seem to give the best life, the aftermarket just doesn't have it together. If you dare, Lenny's 6.1 can be found on Mobilitysite, read up on it lot's if you decide to go that way.
Dec 23, 2009 | Dell Axim X51v Pocket PC
freerider mayfair, no life at all in scooter
Look carefully , you will find a fuse , gently pull the wires around the seat stem , sometimes it can get buried under the power leads from the battery.
Regards
GeWiz
Sep 30, 2009 | Health & Beauty
The battery takes a charge, but will not power scooter
This scooter require two batteries, not one. It is usually a good idea to replace both batteries at the same time, even though one is obviously bad, and the other "seems" okay. These 12 volt DC batteries (VDC) work in tandem to produce the 24 volts that the scooter operates on. In a perfect world, they would both live a long and happy life, but reality is that some die young, others old. Since they are joined together, the one that's going out saps the life out of the other one, so take a bullet and replace both batteries. Make sure you completely charge the scooter when you get the new ones in. Verify that your charger is working properly. To properly charge the 24 VDC system, the chargers have to have an output of about 26-28VDC. The output must be higher than the rated voltage of the two batteries put together to charge. While you have the shell off the scooter, you can see if the charger is working by measuring across the terminal on each battery with the charger off. Note the meter reading. It should be 12-13 VDC. Put it on the charger and retake the reading, and each battery should show an increase in the voltage due to the boost from the charger. After three hours, each battery should show about a 13.5 VDC reading which should hold above 12 for a good 8-10 miles. Always charge your batteries overnight, and if not in use, disconnect them completely with a full charge on the batteries.
Jul 11, 2009 | Golden Technologies Avenger 4 Wheel...
Scooter battery problem
lots of things come into it driving up steep hills,useing lights,but you can get a larger amp hour battery witch make it last longer
Sep 28, 2008 | Amigo Rd 3 Wheel Scooter with 33AH Battery...
1,160 people viewed this tip
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
