Tip & How-To about Hitachi Office Equipment & Supplies
Service menu codes hitachi misc.
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
PROJECTORS :
* Press the {MENU} & {RESET} buttons and then press
the {RESET} button again and hold it for at least 5 seconds.
* The Service Menu will be displayed.
* To exit, turn the Projector Off.
MISC :
1.
* Turn the TV on.
* Press the {MENU} {MENU} {8} {SELECT} buttons on the remote.
* Use the {UP} {DOWN} buttons to select items.
* Use the {LEFT} {RIGHT} to change the data.
* Press the {EXIT} button to exit the Service Menu.
2.
* Turn the TV off.
* Press and hold the {INPUT} button on the TV then press {POWER}.
* Hold both buttons until the TV powers on
with the Service Menu displayed.
3.
* Turn the TV off.
* Press {POWER} & {INPUT} buttons on the TV for more than 3 sec.
* The letter "P" indicates picture and "A" indicates audio.
* Press the {EXIT} key to exit the Service Menu.
I need a service menu code for a rca sld58g45rq tv.
* Turn the TV off.* Press simultaneously the {MENU} {VOL -} {CH -} buttons for about 8-10 seconds.
* The TV will turn on with the Service Menu displayed.
* Press the {POWER} button to exit. thank you..
Nov 04, 2017 | RCA Televison & Video
I HAVE CHANGE MY TV EPROM I NEED TV CODE TO SETUP
NOTICE: MUST READ BEFORE USING SERVICE CODES!!! RiddledTV.com provides this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes. * Unplug the power cable. * Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet. * Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed. * Use the {CH+} {CH-} buttons to select menus. * Use the {VOL+} {VOL -} buttons to change settings. * Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data. * Press the {MENU} button or turn the TV off to exit.
Aug 06, 2012 | Televison & Video
1,381 people viewed this tip
Top Hitachi Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
