Tip & How-To about Health & Beauty
Use Dry Shampoo to Night Before [TIP]
I use dry shampoo quite often for two reasons:
  1. I dye my hair red and want to minimise colour fading.
  2. I'm really lazy.
In the summer months, I don't want to be washing my hair every single day. Dry shampoo gives me more volume and texture, and keeps my hair matte and fresh.
DON'T spray it all over your head as if it was hairspray. Unless grey hair is the look you're going for, then by all means.
DO use a comb to make a number of partings across your hair - spray down each parting, along the roots. This gets the dry shampoo exactly where you need it, and minimizes the white/grey powdery residue.
Read more: https://www.reddit.com/r/TheGirlSurvivalGuide/comments/1cosu7/tip_use_dry_shampoo_the_night_before/
Health & Beauty Logo
After having Matrix optismooth treatment done on my hair it won't hold hair color. Every time I shampoo I can see the color washing out. I am using permanent color? Why is this happening?
There are a lot of reasons that hair wont hold dye. One is what conditioner you are using before the dye. Some conditioners have silicon in them and coat the hair to the point that it wont allow any dye to penetrate. Another is the brand of dye, some dye is better than others, third is your hair type, this can be checked by a professional but some hair types respond to dye better than others and you have to keep trying to find a brand that works best for you,
Jul 09, 2016 | Matrix Health & Beauty
I USED 5RR MIXED EQUAL PARTS WITH 5B. WITH BLEACH FOOLS. WHEN RINSED THE RED ATTACHED TO THE BLOND PIECES AND TURNED THEM PINK. NOW HOW SHOULD I GET RID OF THE PINK?
when you bleached your hair you removed all the pigment from your hair which is why your hair turned pink. You need to use a color the same level you want to achieve but make sure it is an N ( to put back the primary colors ) this is called a filler. after you rinse and dry then apply the 5RR . it helps to rinse out not shampoo joico color esp the red series then use joico cuticle sealer. don't shampoo your hair for 2 days , it should help with the red fading. always use a filler when coloring bleached hair.
Dec 20, 2010 | Joico VeroColor Permanent Hair Color 9B...
How do you care for wavy hair?
I have wavy hair i know how you feel. Never go to bed with wet hair you will wake up with a big frizzy wave poof ball of hair. Straighten your hair when dry in layers.
When you have wavy or curly hair what you need to do is comb when wet and then straighten your hair after it drys. try to get flatning shampoo, brush your hair with a comb to get out all tangles and do your best with your wavy hair by straightning it alot.
Nov 23, 2010 | Health & Beauty
510 people viewed this tip
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
