Tip & How-To about Bunn CWTF 15-APS Coffee Maker
1. you need a 64 ounce graduated measuring cup or bucket
2. make sure the brewer is heated up to temp and the green light on the front is lit
3. open the front panel of the brewer
4. put the microswitch on the circuit board to "unlock" position
5. make sure the sprayhead is cleaned and open, the brew basket is on, and the measuring cup is in place to catch the water
6. press and hold the brew switch until the inlet solenoid clicks 3 times, then release
7. once the water level is at about 40 ounces, turn the main red switch off and let the rest of the water come out
8. if it brews short, press and hold the brew switch again until the 3 clicks, then press and release the brew switch for 2 more second of brew time (up to 5 times per brew)
9. if it brews too much, press and release the brew switch for two less seconds of brew time (up to 5 times), then press and hold the brew switch until the 3 clicks then release
10. once you get to 64 ounces, put the switch on the circuit board to lock and replace the panel
11. enjoy!
