Tip & How-To about Samsung "UN46D6000 46"" LED ""SMART"" TV "
How to find out the series number and model code of a Samsung Smart TV
1. From your Smart Remote press the Menu button
2. In the menu displayed in the TV , select the support option
3. Select Contact Samsung option in the Menu
This displays the Model number / code, firmware version and other details of the TV. Scroll down the popup menu to view other details of your TV.
Samsung "UN46D6000 46"" LED ""SMART"" TV " Logo
There is musical that plays when I switch on the HARWA 32 inch Smart Tv I want to switch it off.
If you want to turn off the musical that plays when you switch on your HARWA 32 inch Smart TV, you can follow these steps:
1. Turn on the TV and wait for the musical to start playing.
2. Press the "Menu" button on your remote control.
3. Navigate to the "Settings" menu using the arrow keys on your remote.
4. Select "Audio" or "Sound" from the menu options.
5. Look for an option called "Startup Sound" or "Power On Sound." It may be set to "On" by default.
6. Use the arrow keys to select the "Off" option.
7. Press "OK" or "Enter" on your remote to save the changes.
The process may vary slightly depending on your specific model of HARWA TV, but these steps should help you turn off the musical startup sound. If you can't find the option in the settings menu, you may need to consult the TV's user manual or contact HARWA customer support for further assistance.
samsung hg40ee470sk secret menu?
Samsung Smart TV hidden secret menu allows you to do a factory reset and also connect some Bluetooth devices which you were unable to do before. Be careful while fiddling with these options as I cannot take any guarantee if you spoil the TV settings. The Samsung Smart TV I used in the video is Samsung F4500. The secret menu will not open with a smart remote. You may buy or borrow the original normal rectangular Samsung remote to access the secret menu but I am not so sure that will work.
Here are all methods to access the secret menu of different Samsung smart TV:
Method 1
Put the TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu.
Method 2
Turn the power off. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
Method 3
With the TV in standby, press the {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
Method 4
With the TV in standby, press the {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
Method 5
With the TV in standby, press the {DISPLAY} {MENU} {MUTE} {POWER} on the remote.
Method 6
With the TV on standby. On the remote, press Mute followed by 1, 1, 9, Enter in sequence.
Method 7 for Smart TV RU7100, NU7090 Series 7 (suggested by viewer Caleb Harch)
How do I do picture in picture
How to turn on PIP in Samsung TV SAMSUNG STEP 1. OPENING MENU SETTINGS
Click here to know about PIP in Samsung TV.
a). Press MENU key ( 20130724181903971_281z433j.jpg ) from TV remote.
b). Select Picture option and press ENTER key ( 20130724182110969_vyofsac0.jpg ) from TV remote.
c). Select PIP option and press ENTER key ( 20130724182110969_vyofsac0.jpg) from TV remote control.
20130724182409386_3o5go25e.jpg STEP 2. TURNING ON PIP SETTINGS
d). PIP window will open on TV screen. Select PIP and press ENTER key ( 20130724182948520_6zvcucfc.jpg ) from TV remote control.
e). Select On option and press ENTER key ( 20130724183213111_ln8iy22v.jpg ) from TV remote control.
f). Enjoy watching PIP screen.
samsung tv (EURO MULTI) sarvice code
Hello
These are the service modes for Samsung. Check it with.
[1]
Turn on the TV on and select the input that you want to adjust.
# Turn the display off
In quick sequence on the remote press:
{MUTE} {1} {8} {2} {POWER} buttons.
# The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
# Select the function and use the {VOL+} button to enter.
# Save settings and exit by pushing {MUTE} twice then {POWER}.
[2]
With the TV in standby, press the {INFO} {MENU} {MUTE} {POWER} buttons on the remote.
Press the {POWER} button to exit the Service Menu.
[3]
Use the {CH+} {CH -} buttons to select items.
Use the {VOL+} {VOL -} buttons to adjust.
Samsung LE32R7 will not retune since switchover
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
