Tip & How-To about Javelin Systems Inc (81160083W98) PC Desktop
Setup Touch Screen Under Windows XP
Go to:
Start>Control Panel>Add Hardware
Click "Yes, I have already connected the hardware"
Scroll to the very bottom and click "Add a new hardware device"
Click "Install the hardware that I manually select from a list"
Click "Ports (COM & LPT)"
Click "Communications Port"
Click "View or change resources for this hardware"
Find the I/Q and Range settings in BIOS for the Touch Screen
Javelin Systems Inc (81160083W98) PC Desktop Logo
THIS COMPU DOES NOT SUPPORTTHEREQUIRED AODIO COMPRESSION FORMAT
This problem occurs if DSP Group TrueSpeech Audio CODEC is missing or corrupt. Normally this codec comes pre-installed winth windows. Anyways to enable it back follow the below steps:
1. Open Windows Explore goto C:/Windows/System32 and Rename tssoft32.acm to tssoft32OLD.acm
2. Click Here to Download tssoft32.acm save in C:/Windows/System32 folder
3. In Control Panel, go to Add Hardware.
4. Click Next and after it searches choose Yes, I have already connected the hardware Click Next.
5. Scroll down to the bottom of the Installed harware list and choose Add a new hardware device Click Next.
6. Choose Install the hardware that I manually select from a list (Advanced) Click Next.
7. Choose Sound, video and game controllers from the Common hardware types list. Click Next.
8. Click on the Have Disk button.
9. Click Browse
10. Navigate to the C:/Windows/System32 folder
11. Choose $winnt$.inf Click Ok. (if you cant find that file try mmdriver.inf )
12. Click Continue Anyway if you get a warning box.
13. Select DSP Group TrueSpeech Audio CODEC from the list. Click Next.
14. Click Next again to install.
15. Restart the computer.
Done! Voice should now work if you followed the steps correctly...
Cheers.!!!
May 18, 2011 | Yahoo Messenger
how to download driver for iomega super slim dvd portable writer extern
fisrt connect dvd writer this should activate the found new harware wizard if it does not start
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives you should see a yellow ? question mark right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
if these options fail you might have to start the add new hardware wizard manually this might vary depending on your operating system click start control panel scroll to printers and other harware select across to left hand side you will see add hardware tab (in xp) click start control panel hardware and sound you will see add a device in (windows 7)
hope this helps
Apr 08, 2011 | Computers & Internet
How do I get and install the codec Intel IMA ADPCM (11)
Hi There,
The codec should already be there.
Just follow these steps:
1. Click on Start -> Control Panel.
2. Click on Add hardware applet.
3. On the Add Hardware Wizard, click on Next button.
4. Select “Yes, I have already connected the hardware” radio button and then click Next button.
5. Choose “Add a new hardware device” at the bottom of the list and then click Next.
6. Select “Install the hardware that I manually select from a list (Advanced)” and click Next.
7. Select “Sound, video and game controllers” from “Common hardware types” list and click Next.
8. Select “(Standard system devices)” from “Manufacturer”.
Note: To install or reintall video codecs, select “(Standard system devices)” from “Manufacturer” and “Video Codecs” from “Model” instead.
9. Click on “Have Disk…” button.
10. Click Browse button in the Install From Disk dialog box. Navigate to folder C:\Windows\System32, and then locate mmdriver.inf file. Highlight mmdriver.inf and click Open or simply double click on mmdriver.inf file, then click OK in the Install From Disk dialog box.
Click on “Continue Anyway” button if a warning about logo compatibility pops up.
11. A list of audio codecs supported by mmdriver.inf appears on the Add Hardware Wizard.
Aug 27, 2010 | Intel Computers & Internet
Hi I have downloaded drivers for canoscan N676U Scanner but it tis not contain any setup file hence I con not install it and use it.
hi this may be a .inf file install, what you have to do is,go to control panel then add new hardware, then click next at next window,it will then search for hardware, then it will ask is hardware already connected, click yes ( make sure scanner is plugged in) then scroll all the way down to bottom of list to add new hardware,then click at next window install hardware that i manually select from a list,then select all devices,then click the have disk, it will then ask you to direct it to where you have downloaded the driver files to, then it will give you a choice , pick your one then install...done, hope this helps please vote thanks
Jun 08, 2010 | Canon CanoScan N676U Flatbed Scanner
to get free download of dsp group truespeech audio
Here's the download link:
DSP Group TrueSpeech Audio Codec 1.1.1.5
http://www.codec-download.com/modules.php?name=Downloads&d_op=viewdownloaddetails&lid=505&ttitle=DSP_Group_TrueSpeech_Audio_Codec_1.1.1.5
1. Extract tssoft32.acm into your C:/Windows/System32 folder, rename your old tssoft32.acm to tssoft32OLD.acm and rename the new unzipped file tssoft32[Codec-Download.de].acm to tssoft32.acm .
2. In Control Panel, go to Add Hardware.
3. Click Next and after it searches choose 'Yes, I have already connected
the hardware'. Click Next.
4. Scroll down to the bottom of the 'Installed harware' list and choose
'Add a new hardware device'. Click Next.
5. Choose 'Install the hardware that I manually select from a list
(Advanced)'. Click Next.
6. Choose ' Sound, video and game controllers' from the 'Common hardware
types' list. Click Next.
7. Click on the 'Have Disk' button.
8. Click 'Browse'
9. Navigate to the 'C:/Windows/System32' folder
10. Choose '$winnt$.inf'. Click Ok.
11. Click 'Continue Anyway' if you get a warning box.
12. Select 'DSP Group TrueSpeech™ Audio CODEC from the list. Click Next.
13. Click Next again to install.
14. Restart if necessary.
*This was taken from another site
It wast posted by Faizi
Mar 04, 2010 | Asrock 775i65G Motherboard
2,566 people viewed this tip
Top Javelin Systems Inc Computers & Internet Experts
Alun Cox
Are you a Javelin Systems Inc Computer and Internet Expert? Answer questions, earn points and help others
