Tip & How-To about Jacuzzi Whirlpool Bath AMH Spa Jet Nozzle White 1834940
If you cannot find a replacement as they have been discontinued. Try this. Remove the retaining ring and gasket. Take a empty 20oz generic water bottle such as Walmart or Ozarka. A thin plastic bottle. Cut the top out so it will allow the nozzle to fit very snug through the hole. Then trim about 3/8" to 1/2" more material off the bottle. You end up with a V shaped piece. Put the nozzle through the hole and add the gasket and Retainer ring. The plastic makes up the space where the nozzle wore thin. Once replaced in the tub it will still be able to rotate.
3.0L DOHC Engine
Fig. Exploded view of the water inlet connection and the thermostat assembly-3.0L DOHC engines
3.0L OHV Engine
Fig. Exploded view of the water hose connection and the thermostat assembly-3.0L OHV engines
Fig. Remove the upper radiator hose from the water outlet
Fig. Remove the water outlet retaining bolts and . . .
Fig. . . . remove the outlet from the engine
Fig. Remove the thermostat from the water outlet
Fig. Inspect the water outlet connection for cracks or damage
Fig. Thoroughly clean the mating surfaces of the water outlet and . . .
Fig. . . . the engine before installing a new gasket
Fig. The jiggle valve must be in the up (12 o-clock) position after installation into the water outlet
