Tip & How-To about Razor E300 Scooter
AVOID RAZOR SCOOTERS BUY VESPA OR HONDA SCOOTERS. THEY LAST FOREVER.
Avoid razor scooters. I bought one at the goodwill thinking what a deal ... After new bats and wiring still no working. I got taken for a ride alright !
Bought a Vespa and it works beautifully. Hondas are great too. Kids ride very summer. All summer same scooters . Razor is a scam.
Razor E300 Scooter Logo
Can I use my scooter in the rain
hi Morag.
Scooter Riding in the Rain Helpful Safety Tips
or this link.
Can use an electric scooter in the rain
Can I use an electric scooter in the rain? Posted on October 19, 2015 by gridsolarsystemOf course,you can.
How to ride your E-scooter in the rain?
The rainy season is here and it is pouring like cats and dogs. Most of the e-scooter drivers have this one common question in their mind and that is how to ride the e-scooter in the rain? Well, it is a valid question and today we are going to find the best answer to it. One of the main reasons why people feel afraid to drive the electric scooter in the rain is because they think that they might get an electric shock. But in actual e-scooters are perfectly safe even when it is raining.
When should you not ride the E-scooter in the rain?
The foremost important point to keep in mind is to make sure that you should never drive the electrical scooter when the visibility is less. If it is a light rain, then there is no problem but if there is a torrential downpour happening, then you should not venture outside on an e-scooter. Lack of visibility can prove to be quite harmful and hence you should make sure that proper care is being taken during heavy rains.
You should also make it a point that if there is a freezing rain happening then also you should avoid driving the e-scooter. If there are snow and rain happening then, there are chances that the tyres may slip.
Excessive rain may cause the chrome on the electric scooter to turn into rust. Excess of moisture may dampen the chrome plating. Typically, this happens if the chrome plating is of low Hence, you should always make sure that high-quality electric scooter is bought and that you can only get from reputed suppliers.
Never drive through standing water
If you see knee deep water on the road, then you should immediately stop. This stagnant water may get into the scooter and can cause extensive damage to the delicate parts. Moreover, water may lead to soil getting soft and your electric scooter can get stuck in the mud and it becomes difficult for you to get if struck.
You should keep this important thing in your mind and that is to make sure that you drive the scooter at a slow speed. Driving at high speed may cause slippages and may result into
Always wear a safety helmet while riding an electric scooter. Though these scooters can only attain a maximum speed up to 30 mph, but this much speed can prove to be deadly during rainy Hence, controlled and slow speed should always be your first priority.
Finally, never let your kids drive electric scooters on their own during the rainy It is for their safety and you must tell them to avoid driving electric scooters on their own during rains.
The real idea behind driving electric scooter is to enjoy the ride and you can only enjoy your ride by staying safe and by following all the safety precautions. Make sure to follow the points mentioned above so that you can stay safe and also enjoy the rainy season on your e-scooter.
Nov 24, 2017 | The Health & Beauty
batteries were dead. put 2 new 12 volt batteries and hooked them up the way the old ones come out + to+ and - to - I turn the switch on and have no lights, no horn , motor won't run. fuses are all good. I put charger on it to test output and it showed 24 volts, but nothing works on it. Is there anything else I can check on it. Thanks, Bob
Bob make sure that the wiring is connected correctly to scooter controller in other words if the cables from the batteries have a connector that plug into the harness coming from the controller make sure that connectors (if color coded) match up and that they are seated correctly. Look on the underside of your rear shroud for a wiring diagram and make sure that the new batteries are wired in that way Hope this helps
Jun 21, 2011 | Health & Beauty
I ride my scooter and then it turns off..the button pops out and when I push it back in it will work for a few moments then stop again.. is the battery done?
I posted a simliar question. I ended up taking my scooter to a battery store that is licensed to work on razor scooters. They ulitmately concluded the wires to the popup fuse itself were loose. They replaced the popup fuse as well just incase. I have now been using the scooter without the fuse popping every 50-100 feet.
Jan 11, 2011 | Razor E300s Electric Scooter With Seat
razor e300 scooter charger light stays green, batterys not taking a charge. I can hear a click when turning on throtle. battery or module?
I have this same problem? What do you do? I bought a new charger thinking it was that and the light stays green on it too.
Aug 16, 2010 | Razor E300 Scooter
1,649 people viewed this tip
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
William Erickson
Are you a Razor Toy Expert? Answer questions, earn points and help others
