Tip & How-To about Microsoft Windows XP Professional
Remove text on taskbar icons like Windows 7 An easy way to give your Windows Vista box a clean look is to remove the application labels on the taskbar. With a registry hack you can make your Windows Vista taskbar look similar to the Windows 7 icon only taskbar. 1.Click on the start button and type in regedit and hit Enter. 2.Navigate through HKEY_CURRENT_USER\ControlPanel\Desktop\WindowMetrics. 3.Create a new REG_SZ value and call it MinWidth 4.Set the value of MinWidth to 56 5.Restart
In Windows and on a Mac, you can use an icon shaped like an audio speaker to adjust the computer's volume or mute the sound output completely.
Whichever operating system you are running, it is possible to remove the volume icon from the screen.
If you have removed the volume icon accidentally, you may not have a convenient way to adjust your computer's sound volume.
Restore the sound icon to resume using it to adjust the volume or mute your computer's sound output.
Click the "System Preferences" icon on the dock.
If you have removed this icon from the dock, click the Apple icon at the top of the screen, then click "System Preferences."
Click the "Sound" icon in the "System Preferences" window.
Place a check in the box at the bottom of the window labeled "Show volume in menu bar."
The sound icon appears at the top of the screen.
Close the window to resume using your computer. Restoring the sound icon in Windows 7
Click the Windows Orb (Start button), then click "Control Panel."
Click "Taskbar and Start Menu."
If you do not see this icon, click the "View by:" drop-down menu at the top of the window and select "Small icons."
Click the "Taskbar" tab, then click the "Customize" button.
Click the drop-down menu next to "Volume" and select "Show icon and notifications."
Click "OK" twice and close the Control Panel. Restoring the sound icon in Windows Vista
Double-click "Taskbar and Start Menu."
If you do not see this icon, click the "Classic View" link.
Select the "Notification Area" tab. Place a check in the box labeled "Volume."
Click "OK" and close the Control Panel. Restoring the sound icon in Windows XP
Click the "Start" button, then click "Control Panel."
Double-click the "Sounds and Audio Devices" icon, or click "Sounds, Speech and Audio Devices," then click "Sounds and Audio Devices."
Place a check in the box labeled "Place volume icon in the taskbar."
Click "OK" and close the Control Panel. Restoring the sound icon in Windows 2000
Click the "Start" button, then click "Settings" and "Control Panel."
Double-click "Sounds and Multimedia."
Place a check in the box labeled "Show volume control on the taskbar."
Click "OK" and close the Control Panel. Restoring the sound icon in Windows Millennium Edition (ME)
If you do not see this icon, click the "View All Control Panel Options" link.
Click "OK" and close the Control Panel. Restoring the sound icon in Windows 98
Double-click "Multimedia."
Click the "Audio" tab.
Which operating system do you have ? The Window's taskbar organizes open and running programs, provides a quick way to access application shortcuts, and gives easy to access to important computer functions and utilities via the system tray. Most users of Windows center their workflow around the Window's task bar for its convenience and ease of use. With the clock function automatically enabled, users can add the date to their task bar while increasing the space for more application shortcuts.
Add The Date To The Taskbar In Windows XP/Vista Right-click on your Window's taskbar and click "Lock the taskbar" option to remove the check mark next to it and unlock your taskbar. If there is no check mark next to it, do not click it as your taskbar is already unlocked. Move your cursor to the top edge of the Start menu and wait for it to change into a double arrow. Click and hold the left mouse button and drag your mouse upwards until the taskbar physically changes in . When it does, it will add the day and the date under the time. Add The Date To The Taskbar In Windows 7 Right-click on the Window's taskbar and select "Properties" from the resulting menu. Click the check box next to "Use Small Icons" to disable the option. The icons will get slightly larger and the date will appear under the time. Click "Apply" followed by "Ok" to save your changes and exit the window.
Right click on your taskbar then choose properties. On the bottom of the box opened, there is a check box with label "Hide Inactive Icons". Uncheck the box.
