Tip & How-To about Jeep 2002 Grand Cherokee Laredo 4WD
On the 99'-04' jeep grand cherokee they are notoriously known for the radiator fan not running thus causing overheating, it's a well hidden relay under the passenger side headlight that is most likely bad, relay costs about 45 dollars give or take a few dollars, but make sure relay comes with harness that it plugs into because that was the actual factory defective part, just cut off old harness and match wires and replace harness along with relay switch and you should be good for years to come.
