Tip & How-To about D-Link Computers & Internet
All products
Always start with reseting your equipment. Power it down, unplug wait 15-20 seconds min. and power back on. This will fix many issues.
Computers & Internet Logo
hp c410a photosmart printer can't clear paper jam message and get general printer error code ox6100004d.
1) Be certain your Ink cartridges are not fake.
2)
Partial Reset
The partial reset only refreshes the printer into a responsive state and does not delete any setting from your printer. This type of reset fixes printer issues such as an unresponsive printer. Wireless issues, cartridge mismatch and errors and more. I would recommend starting from this type of reset first then if it does not work, try proceeding to a higher type of reset. To to this all you have to do is:
Turn ON the printer.
While the printer is ON. Unplug the power cord from the back of the printer.
Wait for 10 seconds.
Press and hold the "#" and "3" keys on the printer keypads while plugging the power cord back into the back of the printer.
Wait for 10 seconds before releasing both keys.
Your printer should now start to reset.
Semi-Full Reset
The semi-full reset fixes a lot of issues. However it removes all the setting on your printer and you need to re-enter all your settings like printer language, wireless setting, etc.. back into the printer once the reset is complete. To do this all you have to do it follow the same process in doing a partial reset but pressing the "#" and "6" keys instead.
Full Reset
Doing a full reset is not really recommended. This is only applicable when all troubleshooting steps has been exhausted. To do this, all you need to is use the "#" and "9" keys with the same process as the the partial reset.
2answers
hp officejet 6500 all lights are flashing and mechine says turn off and on . Please can someone Help??
: Check the power cord
1.
Turn on the product.
2.
Remove the power cord from the back of the product.
3.
Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Turn the product off and then on again
1.
Press the Power button ( ) to turn the product off.
2.
Wait 60 seconds, and then press the Power button ( ) to turn the product back on.
3.
If the product does not turn off when the Power button ( ) is pressed, wait three minutes, and then proceed to the next solution.
Plug the product into a wall outlet
Follow these steps to make sure the product is plugged in correctly.
1.
Unplug the power cord from the back of the product.
2.
Unplug the power cord from any surge protectors or power strips.
3.
Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4.
Plug the power cord into the back of the product.
5.
Plug the power cord into the wall outlet.
6.
Press the Power button ( ) to turn the product on.
Solution six: Reset the product
Follow these steps to reset the printer.
1.
2.
Unplug the power cord from the wall outlet.
3.
Wait 10 seconds, and then plug the power cord back into the wall outlet.
4.
NOTE: Many power cords have an LED light on the power module or on the end of the cord that plugs into the product. Make sure the LED light is lit and steady.
5.
6. Perform a partial reset of the product
  1. Disconnect the power cord from the product.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while reconnecting the power cord.
  4. When the product turns on, release both buttons.
  5. Try printing again.
IF still won't resolve it by following steps mentioned above then your printer needs replacement. Malfunctioning hardware.
Can only connect to the internet wirelessly for about 2-3 mins before signal drops off and can't get it back. Router is new last month and started noticing usage issues last week. On the face of the router the airport bars are constantly flashing. Is my router dead or is there something I can do to remedy this issue?
I'd start off with a hard reset by holding down the reset button down in the back of the router for 15 seconds, I usually cut the power, hold the button down for 15 seconds, power it back on, wait another 15 seconds, THEN I release the button.
That will set everything back to default. Once you've got the router up and running again I would check D-Links support page to make sure you've got the latest firmware version.
That should address your issue, if not, contact D-Link support for an RMA ;)
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
3answers
i can't access ther router using 192.168.0.1
Hi Wafula,
Unplug the Dlink, wait 2 min, and plug it back in. If that work, on the back is a small hole, marked RESET. Using a pencil, or straightne out a large paperclip, press that the button inside gently. Hold it for 30 sec. Release and unplug the unit. Shut down the whole network. "Starting from the wall", power up the modem, wait 2 min, power up the Dlink, and power up your machine. Your Dlink should be at default now. Remember to reset you security, change the password, etc.
I have had to do this several times, sometimes unplugging the power, and plugging it back while holding the button. (Got 3 hand?)
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
