Tip & How-To about Sony Walkman WM-FX141 Personal Cassette Player
Player too slow
If the walkman is too slow, try the a new belt, batteries and cassette.
Sony Walkman WM-FX141 Personal Cassette Player Logo
New tape playing too fast. What do I do to slow it to normal speed?
You have to replace the IC 601, probably burns because of some passive components that must be replaced. "Doctor.walkman @ gmail.com"
2answers
I have a sony walkman WM-3. It suddenly stopped playing. Do you do repairs ?
Please check for the belts if the battery you have installed is new and the set gives a hum on play. If not you will have to check the power switch, the mechanism switch and the line to the main board.
If the motor turns but not the capstan and the reel then change the belt, the rollers or the pulley. I hope this will get your set back to action. Good day
tape speed distorts and slows
motor belts are cheap. try replacing the belt that drives the wheel. this become distorted specially when the unit has not been use for quit long time. if you think its not about belt, clean up the rubber that touches the tape when played, also the tape head with 70% alcohol. hope this help.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
